Deck Railing ? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-02-2006, 12:12 PM   #1
Deck Railing ?
Hi Just joined am looking forward to the information shared on this site.
I have a deck which is very narrow in depth 7'9" width is 30'. I want to build a "slanted railing to utilize a "full view" and not feel like I am in jail. I am up on a hill and it is a great view. With the old railing(which I tore down) I couldn't see a thing. Not interested in glass just a slant to the rail. I know it is not code but can anyone assist?
Thanks to all in advance,
JayI
JayI is offline   Reply With Quote
Old 08-12-2006, 04:39 AM   #2
rdp
Rewards Points: 87
Jay - You might need to elaborate more on the concept of a "slanted" deck railing. Slanting the railing doesn't seem to offer more visability, in my opinion. What am I missing here?
For greater visibility through deck railings if allowed by your local building codes, some have gone to anodized aluminum tubing. For instance, a black vertical tube, .750 inches O.D., set 6 inches apart, provides a lot less obstruction than a 2 x 2 wood rail.
Hope that helps.
powrus is offline   Reply With Quote
Old 08-12-2006, 11:48 PM   #3
If you know it's not code, why pursue this questionable practice?
Guardrails on decks are there to provide protection from falls.
Your current deck does not conform to most codes which require all platforms to be at least 36" wide in all directions.
Your best option is to use a vertical deck rail after extending the width of your deck to more than 36" ....
manhattan42 is offline   Reply With Quote
Old 08-13-2006, 04:41 AM   #4
rdp
Rewards Points: 87
Manhattan42 -
Earlier you posted the following:
" I know it is not code but can anyone assist?"
Whose quote is this?
Old 08-13-2006, 06:26 AM   #5
Framing Contractor
Originally Posted by powrus
Manhattan42 -
It's Jay1's quote in the last sentence of his post. Read it. He's looking for advice on doing something that's not code.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 09-08-2006, 08:57 PM   #6
Switching gears just a bit, I'm interested in vinyl railings with glass inserts. Have not found them anywhere. I know Dekorators sells the glass inserts 5 pcs for 60 bucks but how do I find a vinyl rail that will accept the glass? All the vinyl railings at HD & Lowes are pre-drilled for the vinyl inserts. Ideas?
Buzzbob is offline   Reply With Quote
Old 09-09-2006, 01:37 PM   #7
Darylh's Avatar
Slanted railings where use alot up here in the 70's, what they do is give you more elbo room and a sence of more space. You can also build in seat benches to but I am not sure if this kind of railing is allowed anymore..Check with your Building Department.
Now no matter what railings you use you must not have more than a 4 inch space and the railings have to be at least 42 inches high at least up here. Now your insurance company follows your building codes so if you build railings that are not to code and someone falls or hurts them self or worse your insurance will not cover you and thats one of the reasons why its so important to follow the codes in you area.
Aluminum rails are a great way to get more veiw, but I would go with aluminum and glass myself.
Darylh is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 07:12 PM
Top Cap on Deck Railing cibula11 Building & Construction 5 07-25-2007 06:17 PM
Deck Height w/out step DLP600 Building & Construction 4 04-19-2007 11:34 AM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 09:50 PM
