Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-23-2011, 08:34 AM   #1
Deck Railing
Hello,
I am installing the cap piece on my deck railing. On the long run I joined two pieces together by putting a 45 degree cut on the ends of each board (Scarf Joint?) My question is, I am now coming to the ends of my deck where it is angled like an octagon. Once I find the angles that I need to cut the boards, do I also "Scarf" joint them or just butt joint them? (IE: The angle will be 22 1/2 to make a 45, but do I also use the compound mitre to make a scarf joint?)
Smoke is offline   Reply With Quote
Old 10-23-2011, 08:56 AM   #2
Moderator
kwikfishron's Avatar
Deck Railing
I never do it that way but you certainly could.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 10-23-2011, 09:00 AM   #3
Deck Railing
I would think a butt joint would be fine.
Joeychgo is offline   Reply With Quote
Old 10-23-2011, 09:05 AM   #4
Civil Engineer
Deck Railing
A butt joint with a biscuit works very well.
Old 10-23-2011, 10:01 AM   #5
journeyman carpenter
woodworkbykirk's Avatar
Deck Railing
but joints are the most common.. making a scarf joint on the end is just time consuming
woodworkbykirk is offline   Reply With Quote
Old 10-23-2011, 10:37 AM   #6
Moderator
Deck Railing
DIY just might have the time. Couldn’t be a bad thing with wood since the heels usually open up on you some day anyway.
-NEW MEMBERS-
Old 10-23-2011, 10:53 AM   #7
Deck Railing
Thanks for all the replies, I think I'm just going to butt the angles. When you start "Scarfing" the chances of all those edges lining up perfectly gets slim with the way the different pieces of wood lay. Thanks again!
Extending height of deck railing tntworks General Discussion 4 03-11-2013 08:16 AM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Deck Staining Nightmare steven994 Painting 2 06-17-2010 08:21 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
