-   -   Deck Railing (http://www.diychatroom.com/f14/deck-railing-120992/)
Smoke 10-23-2011 07:34 AM
Deck Railing
Hello,
I am installing the cap piece on my deck railing. On the long run I joined two pieces together by putting a 45 degree cut on the ends of each board (Scarf Joint?) My question is, I am now coming to the ends of my deck where it is angled like an octagon. Once I find the angles that I need to cut the boards, do I also "Scarf" joint them or just butt joint them? (IE: The angle will be 22 1/2 to make a 45, but do I also use the compound mitre to make a scarf joint?):confused1:
kwikfishron 10-23-2011 07:56 AM
199 Attachment(s)
I never do it that way but you certainly could.
Joeychgo 10-23-2011 08:00 AM
I would think a butt joint would be fine.
Daniel Holzman 10-23-2011 08:05 AM
A butt joint with a biscuit works very well.
woodworkbykirk 10-23-2011 09:01 AM
but joints are the most common.. making a scarf joint on the end is just time consuming
kwikfishron 10-23-2011 09:37 AM
199 Attachment(s)
DIY just might have the time. Couldn’t be a bad thing with wood since the heels usually open up on you some day anyway.
Smoke 10-23-2011 09:53 AM
Thanks for all the replies, I think I'm just going to butt the angles. When you start "Scarfing" the chances of all those edges lining up perfectly gets slim with the way the different pieces of wood lay. Thanks again!
