Deck Questions - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-10-2007, 10:33 AM   #1
Question
deck questions
Hello,
I have a few questions about the construction of the deck I will be undertaking soon.
1. What type if any adhesive do I need to use between the joist and decking I will be using trex 5/4X6 deck boards?
2. I plan to have a 32" cantaliver on the sides of the deck is this ok? I will be using double 2X10 beams setting on 6X6 post with 2X8 joist laid on top of the beams.
3. I plan to do some built in benches using the trex decking 2X4 and 5/4X6. will this material be strong enough, or do I need to buld the framing for the benches out of lumber?
apowens is offline   Reply With Quote
Old 04-10-2007, 10:41 AM   #2
Rewards Points: 1,088
Congrats on your future undertaking.
1. Adhesives aren't generally used, as fasteners are typically installed on each overlay of the board on top of the joist.
2. For 2', it's generally ok to cantilever, but over that, at lest 4x4's are recommended.
3. Composite decking flexes a great deal as it has little structural rigidity. It is definitely recommend to build the framing for it. If so desired, the framing can be hidden with composite trim.
handy man88 is offline   Reply With Quote
Old 04-10-2007, 10:46 AM   #3
Smile
thanks
Yes I will be using a hidden fastner system. I wasn't sure if i should the adhesive also.
will reduce down to a 2' over hang.
thanks,
Old 04-10-2007, 05:27 PM   #4
zel
Rewards Points: 150
Send a message via AIM to zel
Trex is not meant for framing, so you will need a PT wood frame.
zel is offline   Reply With Quote
Old 04-10-2007, 06:14 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I don't know the size of your deck....but generally, we always use a minimum of a 2x10 for joists and 2x12's to fabricate the beam....(most standard sized decks),...
Also 4x6 to 6x6 posts are the industry prefered post sizes....
- Build Well -
Old 04-10-2007, 07:23 PM   #6
fhi vinyl windows
fhivinylwindows's Avatar
Rewards Points: 150
Make you that your local building dept. approves your plans before you start.
fhivinylwindows is offline   Reply With Quote
Old 04-10-2007, 07:35 PM   #7
Absolutely....They can also be a very valuable resource for guidance in the construction of your deck for your particular region....
- Build Well -
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 07:12 PM
Deck questions DLP600 Building & Construction 12 04-29-2007 11:22 AM
deck questions robphelan Carpentry 6 06-25-2006 06:42 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 09:50 PM
