Deck Project - Shim Beams Or Joists? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-08-2009, 02:14 PM   #1
Deck project - Shim beams or joists?
Hi Folks,
I'm starting to install the beams on a deck project, and have a question. In this case, the posts are 6x6 treated lumber, and have been notched to accept the beams in this fashion:
The question i have is that the 2x12 beams are (of course) not all the same width, varying from 11" to 11 3/8". My first attempt has been to keep the tops even and shim the beam to post connection with a ripped (not crosscut) section of treated lumber. But now i'm wondering if i shouldn't just let the beams rest on the post and shim the joist connections.
The third option would be to not shim anything and just let things settle where they may, but I don't know if I really like that option.
Any suggestions before i hang the rest of them? Does it matter a lot either way?
Thanks!
jcims is offline   Reply With Quote
Old 08-08-2009, 09:02 PM   #2
Old School
Willie T's Avatar
Can you recut the post notches, all to the height of the lowest one? Very carefully, this time.
Willie T
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 08:46 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Building a deck - another project for later this summer (Question re: materials) DyerWolf Carpentry 8 05-07-2009 02:41 PM
Adding supports for beams and joists pinkertonpv General DIY Discussions 2 08-13-2008 03:04 PM
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 09:01 AM
