Deck Guard - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 01:42 PM   #1
Rewards Points: 1,062
Question
deck guard
was wondering if deck guard needs to have any structural support connection to the joists or even girders/ledgers through the surface decking board or is it OK to have it installed at the very end after all the decking boards have completely covered access to the structural layer underneath.
basically, i was gonna set decking board so that i can at least use the deck for accessing the house from that end but install the guard later as a matter of lesser priority (it is not dangerous since the deck is only 20" high). but if i need to set guard corners or something before setting decking board, that would change the sequence...
thanks
Old 02-06-2011, 05:46 PM   #2
Contractor - Renovations
fungku's Avatar
If you are talking about railings, and you are building yours, then it's better to do those first.
You will want to do proper blocking and/or hardware for a solid railing and need to work on it before you put the decking down for a deck that low.
fungku is offline   Reply With Quote
The Following User Says Thank You to fungku For This Useful Post:
amakarevic (02-07-2011)
Deck Staining Nightmare steven994 Painting 7 06-14-2017 04:56 AM
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
Deck Guard posts on top of deck posts -how? davis_mc Carpentry 1 04-18-2010 07:42 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
