Deck Coverings - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-19-2009, 11:51 PM   #1
Thumbs up
Deck coverings
Need information on how to waterproof a 8x12 foot upper deck---I want to use the under area for storage--it's covered with 2x6s with spacing between-- Can I caulk between the 2x6s and use marine grade 1/4 in. plywd with some sort of fiberglass overlay? I would use quad caulking for all seems. This deck gets very little use. Thanks
daryel is offline   Reply With Quote
Old 07-20-2009, 07:13 PM   #2
General Contractor
There are systems available that you can mount under the deck platform. I can't think of a manufacture right now but I'll see what I can dig up for you.
ARI001 is offline   Reply With Quote
Old 07-20-2009, 07:18 PM   #3
Rewards Points: 774
I would agree with ARI001, there are systems available. The ones that I have seen look like corrugated metal and channels the water away from the area. If it was too expensive plywood and caulk should work too. You just don't want water to sit between the joists and be held by the plywood.
cibula11 is offline   Reply With Quote
Old 07-21-2009, 09:31 AM   #4
General Contractor
Go to these websites for more information:
www.diyhomecenter.com
www.magnoliaunderdeck1.com
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 07:46 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 03:42 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
