Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-15-2009, 12:29 PM   #1
deck cantilever
How far can I cantilever from a beam for a new planned deck? Let's assume 2x8 joists 16" oc over a doubled 2x10 beam.
Thanks!
ashukoff is offline   Reply With Quote
Old 07-15-2009, 02:08 PM   #2
General Contractor
deck cantilever
Here you can overhang max 3' with a 2"x8" SP#2 16 o.c. and no roof load. Code requires solid blocking over the beams when doing so. I would refer that question to your local building department to make sure its the same in your area before doing it that way.
ARI001 is offline   Reply With Quote
Old 07-15-2009, 02:48 PM   #3
Newbie Bill
deck cantilever
Yes, check into your local code.
Where I live the formula is 2.5 times the depth of your joists up to a maximum of 24". So in your case with 2X8 lumber the maximum cantilever you can have is 20".
Your codes in your area are most certainly different.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 07-16-2009, 09:00 AM   #4
deck cantilever
Thank you for the info!
Old 07-18-2009, 05:33 PM   #5
SNC
deck cantilever
Rule of thumb is 2 feet back and one foot overhang.
We did some water front condos in MD some years ago that had a 60% overhang . If I remember we had a bean 4 foot off the building and the cantelevier was 5 feet with a 4x band we used revers crowns and upside down hangers.
I have the photos someplace around here.
SNC is offline   Reply With Quote
Old 07-23-2009, 01:27 PM   #6
deck cantilever
Backspan to cantilever ratio needs to be at least 2:1
And depending where you live
Snow load................... 30psf........... 50psf.......... 70psf
Max Cantilever Span...... 42"............. 34"............. 29"
Based on 2 x 8 16oc
JonM is offline   Reply With Quote
Hanging deck stairs on a cantilever drtbk4ever Building & Construction 11 07-14-2009 09:13 AM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
Attaching deck ledger to cantilever ram80ran Building & Construction 13 04-18-2009 01:29 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
