Deck Boards On Pt Plywood? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 10:57 PM   #1
Deck boards on pt plywood?
For an underdeck shed , advice on sheeting the joist with pt plywood and putting deckboards on the plywood. Trying to make the "shed" as waterproof as possible and its 5' or so , so would prefer to try and keep as much headroom as possible. Any advice is appreciated
BigTy is offline   Reply With Quote
Old 05-23-2011, 02:12 AM   #2
So this underdeck shed will be subject to rain and water I take it?
if you are putting plywood down on the joists, you should create a slope with sleepers, and then put your plywood down. If you put down deckboards with a proper space between each board, then you do not have to worry about water pooling, like you do with the plywood. Hence the need to create slope.
chrisBC is offline   Reply With Quote
Old 05-23-2011, 08:35 AM   #3
Rewards Points: 5,336
I wouldn't do this. Water would be trapped on top of the plywood. Pressure treated or not, it will rot.
Ron
How to deal with expansion of deck boards? darsunt Building & Construction 3 02-02-2011 09:33 PM
new second story deck stair, platform question walt1122 Building & Construction 10 11-12-2010 09:52 AM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 10:15 AM
Sanding rough PT deck boards houseinthewoods Painting 2 06-24-2010 06:27 AM
Subfloor repair Dave321 Flooring 3 09-16-2009 08:59 PM
