Deck Boards Intersecting With 45 Degree - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-12-2010, 04:05 PM   #1
Deck boards intersecting with 45 degree
Hi all
I'm trying to intersect a 45 degree deck board to edge 90 degree cut board. Of course when I cut 5/4 x 6" deck board on an angle, the width across the angle is now more than the 6" board cut straight.
How do I properly intersect the boards? I suspect the proper answer is to make both sides 22.5 cuts but unfortunately I have already attached the straight cut boards.
Can I do a couple extra cuts on the top and bottom of the 45 degree angle? How far back would I need to move back on the board?
Thanks for your help.
Garth
GarthH is offline   Reply With Quote
Old 09-12-2010, 07:09 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
i think its geometrically impossible
Tom Struble is offline   Reply With Quote
Old 09-12-2010, 07:23 PM   #3
I think you are right also.
I need to pull up what I have and start again.
What does everyone have to measure angles? I've tried a variety of tools but end up using trial and error. Doing this project will have a lot of angles.
Thank you
Garth
Old 09-12-2010, 07:43 PM   #4
how about using a ''seam board''to separate the 2 angles
Old 09-12-2010, 08:07 PM   #5
Framing Contractor
Thank you
Garth
Can't you cut the 90dgree boards at 22.5 degrees?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 09-13-2010, 07:04 PM   #6
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
If your angles are good, you can use the bevel gauge in your miter saw to cut the angles. If your lines are off, then use a bevel gauge to lock in the bevel between the pieces and then use protractor to measure it.
If you are trying to figure out how to determine what the bevels are, look at the attached pdf. A horizontal piece runs left to right. Another piece runs into it on a 66 deg bevel. The angle between the two pieces is 114 deg (180 deg - 66 deg), so you split it in half and miter both ends at 57 deg.
WirelessG is offline   Reply With Quote
Deck Staining Nightmare steven994 Painting 7 06-14-2017 04:56 AM
Composite Deck Boards dgoodwin3364 Carpentry 10 06-05-2009 11:09 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Cedar Deck boards Outbacker Painting 2 03-04-2006 01:12 PM
