Deck Beam Crowned Not Hitting Middle Posts - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-22-2010, 08:51 PM   #1
I have a deack beam and it is 16 feet and it is crowned I have 4 posts and it is on he end posts but is about 1/8 to 1/4 of an inch off the mddle posts due the the crown. How can I pull these down. I dont want to attached the beam to post caps until it is on the beam. Let me know yout thoughts.
2 threads on same issue merged
Dabber0069 is offline   Reply With Quote
Old 08-22-2010, 09:36 PM   #2
jlhaslip's Avatar
Rewards Points: 2,884
add the joists, decking and handrail then check it.
the reason the crown is 'up' is to have the weight of the deck straighten it... sort of.
attach the middle posts to the beam and brace them plumb.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
drtbk4ever (08-23-2010)
Old 08-23-2010, 08:06 AM   #3
Not so new
12penny's Avatar
Rewards Points: 520
dabber...you cant really pull it down. Possible to cut new posts? This is the reason I wait until beam is set to cut the center posts.
12penny is offline   Reply With Quote
Old 08-24-2010, 01:22 PM   #4
Registered User
Rewards Points: 526
I would just cut the beam half-way through from the bottom over the middle posts. Stronger than using 3 shorter beams.
Be safe, Gary
Old 08-24-2010, 05:34 PM   #5
Not so new
12penny's Avatar
Rewards Points: 520
GBR... interesting thought. Thanks. But I was thinking more about making the posts fit the beam. I guess as long as you get to where you need to be.
Old 08-24-2010, 06:19 PM   #6
kwikfishron's Avatar
Rewards Points: 1,008
If you have a beam with an excessive crown over a post you cut the beam, problem solved.
kwikfishron is offline   Reply With Quote
Old 08-24-2010, 06:24 PM   #7
Framing Contractor
Are the joists and decking on yet? Or, just joists? If there are no joists and decking on yet, install the joists and watch the weight of the joists push the beam down to the posts and then fasten. If the joists don't do it wait until you start putting the decking down.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-24-2010, 08:43 PM   #8
Registered User
Rewards Points: 526
Notice how this room echos? ? ? lol
Be safe, Gary Gary
New deck - Gap between beam and post due to shrinkage? DaveNJ Building & Construction 3 07-06-2010 07:23 AM
Deck structure question houseinthewoods Building & Construction 5 06-13-2010 09:18 PM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 06:14 AM
Deck Posts question flyultralite Building & Construction 1 06-23-2007 09:18 AM
UGH! just realized one of my deck posts is cut too short nasdaqer Carpentry 8 06-19-2007 07:26 AM
