Deck Balusters (3 Or 4) Split When Nailed--replace? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-14-2010, 02:49 PM   #1
Deck balusters (3 or 4) split when nailed--replace?
Hi --
I need advice about a new deck that a contractor constructed for us (completed yesterday). We just noticed today that 3 or 4 or the deck balusters are split at the lower end, from the nailing. The contractor is coming back on Monday to do some roof work, and I want to point these out to him and ask him to replace them. We like the contractor and overall appreciate the good work.
My spouse thinks we should let this go - I think we should discuss this with the contractor.
Advice?
Thanks.
Carolina is offline   Reply With Quote
Old 05-14-2010, 05:17 PM   #2
Rewards Points: 5,336
Originally Posted by Carolina View Post
Hi --
Advice?
Thanks.
The balusters should be replaced. Suggest to the contractor the concept of, "pre drilling". They love the guidance.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
MTN REMODEL LLC (08-29-2014)
Old 05-14-2010, 06:06 PM   #3
Ron
Um, Ron--they love the guidance? You're going to get me yelled at, I think.
They did work fast, as my husband pointed out, and so didn't pre-drill the holes--which I wouldn't have cared about if the splitting hadn't shown up. How would you do it: would you say "Scott, I'd like to have these balusters replaced b/c of the splitting" or "Scott--these balusters split because they weren't pre-drilled" and wait to see what he says.
Old 05-14-2010, 06:46 PM   #4
Stairguy
Millertyme's Avatar
Rewards Points: 508
i would just play dumb. Show them to him and ask him if he thinks it will be a problem in the future. He will know that you noticed it and should take it upon himself to fix it. I know If I were the contractor I would fix. Stuff like that happens all the time.
Millertyme is offline   Reply With Quote
The Following User Says Thank You to Millertyme For This Useful Post:
Carolina (05-15-2010)
Old 05-14-2010, 07:49 PM   #5
This is an insignificant cost issue. Play to his professionalism. Any good contractor would replace the balusters in a heartbeat.
Ron
The Following 2 Users Say Thank You to Ron6519 For This Useful Post:
Carolina (05-15-2010), Willie T (05-15-2010)
Old 05-14-2010, 08:01 PM   #6
kwikfishron's Avatar
Rewards Points: 176
Don’t tell your contractor "how to do it", especially if all else is good. Just ask him to change the 3-4 pickets. It should take 5-10 min.
A small punch list from customers is a very common thing and any contractor that cares about customer satisfaction and good referrals won’t bat a eye.
If he spends 20 min. telling you why he shouldn’t make you happy with a 5 min. fix then hold back some bucks at the end till he does.
kwikfishron is online now   Reply With Quote
Old 05-15-2010, 11:46 AM   #7
Originally Posted by kwikfishron View Post
If he spends 20 min. telling you why he shouldnĺt make you happy with a 5 min. fix then hold back some bucks at the end till he does.
If only. I paid him before he left on Thursday. Naive, I guess - it never occurred to me to closely inspect things. I just admired the overall work and wrote the check.
I under-counted before: there are 11 balusters with cracks. I'm assuming that any contractor with a reputation to maintain would be glad for the chance to put this right, especially since we've arranged with him to do some roof repair and would be glad to recommend him in the future.
Right?
Old 05-15-2010, 01:24 PM   #8
Old School
Willie T's Avatar
Right?
The time-frame should make no difference to any reputable contractor. I can't imagine anyone but a sloven hack saying, "Ah Ha! You didn't catch those splits before I got the check... I'm home, free."
If he any kind of a man worth rehiring, he'll fix them.
But, for Pete's sake, don't let him do your roof work if it does happen to turn out that he baulks on these baluster repairs.
Franšois Duc de La Rochefoucauld
Willie T
The Following 2 Users Say Thank You to Willie T For This Useful Post:
Carolina (05-15-2010), MTN REMODEL LLC (08-29-2014)
Old 05-17-2010, 11:14 AM   #9
Continuing saga of our deck
The contractor who built our deck placed the deck floor boards right together. My husband asked him about spacing since he had in the past built a deck by our pool and had left open space between boards. The contractor, though, told him that as the boards dried, the proper amount of space would open up between them. So in addition to the split-baluster problem, now I'm worried that the deck floor hasn't been done properly, and that rain water is simply going to always pool on the deck as it has been doing these last few days (apparently building a deck affects the upper atmosphere, causing increased rain...)
Should I be worried?
Old 05-17-2010, 01:15 PM   #10
I installed my PT boards as tight as I could, I even used a clamp/small sledge to get them tight
Plenty of space between the boards after they dried
What type of wood ?
Old 05-17-2010, 01:41 PM   #11
Newbie Bill
Rewards Points: 520
Type of wood and location will have a tremendous bearing on this.
So as Dave asked, what type of wood and where do you live.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 05-17-2010, 02:05 PM   #12
We live in the upper northwest corner of S.C. The wood is pine, which I know tends to split.
Old 05-17-2010, 04:41 PM   #13
Is this pressure treated southern yellow pine? If so, it shouldn't be an issue. You said he did the other deck. Was the installation the same? Are there any issues with that deck?
Ron
Old 05-17-2010, 05:20 PM   #14
No, my husband did the other one, years ago, but it's a ground-level deck, no railings so no balusters to worry about. (Sorry - I added the deck floor question to the original thread on balusters; may be confusing.) But on this new contractor-built deck, about 11 balusters have splits at the site where the nails were air-hammered in, so I've been seeking (and getting) advice about how to handle that with the contractor when he returns to do some roof work (Wed.). Thanks!
Old 05-17-2010, 05:33 PM   #15
It would help if you answered the questions.
It doesn't really matter who did the other deck, but more about the construction methodology. The type of wood and the way it was installed.
Ron
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
Patio Around an Existing Deck tonyg Landscaping & Lawn Care 1 09-10-2009 07:57 PM
Double Level Deck 6x6 posts Skytree Building & Construction 3 09-07-2009 11:47 AM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 08:03 PM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
