Deck - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 05:03 PM   #1
deck
does anyone know what the building code is for sono tube's for a deck i got three feet from the bottom of door to ground do i need sono tube's
buddyrow is offline   Reply With Quote
Old 03-20-2011, 09:45 PM   #2
Rewards Points: 5,336
Originally Posted by buddyrow View Post
does anyone know what the building code is for sauna tube's for a deck i got three feet from the bottom of door to ground do i need sauna tube's
Sonotubes? The code is based on the frostline and the weight of the structure.
In lower NY, the frostline is 36", so the 12" (in diameter)sonotubes go into a hole about 40" deep.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
buddyrow (03-21-2011)
Old 03-21-2011, 06:08 AM   #3
What he said, sonotubes are for setting footings to below the frost line. That varies with where you live. Water weighs about 8lbs/gal, plus the weight of bodies and the tub. Overkill design is never a bad thing.
Hot tubs are often set at or near the deck level so you just step down into it. If you want it on the top of the deck, you need to at least, double the deck support structure(double 2x joists, extra blocking, and footers.
The Following User Says Thank You to Just Bill For This Useful Post:
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 10:15 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
