Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-28-2013, 04:23 PM   #1
Deck
Hello
1. Any good software programs to help design a wood deck? that would be attached to a brick wall (exterior of house).
2. Any good spots or directions that i could read? Learn?
thank you for your help.
PTMD
Amitabh is offline   Reply With Quote
Old 01-28-2013, 05:04 PM   #2
Deck
Single story house?
Old 01-28-2013, 05:09 PM   #3
Deck
I've used this one before and it's easy to use.
It gets you close but will not let you change the material list for things like through bolting the rim joist, and screws instead of nails for the decking.
http://bighammer.com/
But it will give you a footing lay out, framing layout, and a 3D drawing of what it will look like when done.
Old 01-28-2013, 05:59 PM   #4
GBrackins's Avatar
Deck
cannot attach to brick, does not provide proper bearing ......
as far as reading material check these out
http://www.awc.org/publications/DCA/DCA6/DCA6-09.pdf
http://www.deckmagazine.com/
http://www.jlconline.com/coastal-con...tal-decks.aspx
http://nadra.org/
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 01-28-2013, 06:39 PM   #5
Deck
If it's a single story plan on making it free standing (not attached to the house)
Never have it any closer the 4" of any door openings.
Use 6 X 6's not 4 X 4's.
Do not just attach the the rim joist to the outsides of the post, you need to cut into the sides of the 6 X 6's instead.
Trying to "save" money by under sizing the joist is a very common big mistake.
Though bolt all the rim joist, do not just nail them.
Only use ACQ apprive fastners!
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 04:27 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Deck Staining Nightmare steven994 Painting 2 06-17-2010 08:21 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
