-   -   Deck (http://www.diychatroom.com/f14/deck-170387/)
Amitabh 01-28-2013 03:23 PM
Deck
Hello
1. Any good software programs to help design a wood deck? that would be attached to a brick wall (exterior of house).
2. Any good spots or directions that i could read? Learn?
thank you for your help.
PTMD
joecaption 01-28-2013 04:04 PM
Single story house?
joecaption 01-28-2013 04:09 PM
I've used this one before and it's easy to use.
It gets you close but will not let you change the material list for things like through bolting the rim joist, and screws instead of nails for the decking.
http://bighammer.com/
But it will give you a footing lay out, framing layout, and a 3D drawing of what it will look like when done.
GBrackins 01-28-2013 04:59 PM
cannot attach to brick, does not provide proper bearing ......
as far as reading material check these out
http://www.awc.org/publications/DCA/DCA6/DCA6-09.pdf
http://www.deckmagazine.com/
http://www.jlconline.com/coastal-con...tal-decks.aspx
http://nadra.org/
joecaption 01-28-2013 05:39 PM
If it's a single story plan on making it free standing (not attached to the house)
Never have it any closer the 4" of any door openings.
Use 6 X 6's not 4 X 4's.
Do not just attach the the rim joist to the outsides of the post, you need to cut into the sides of the 6 X 6's instead.
Trying to "save" money by under sizing the joist is a very common big mistake.
Though bolt all the rim joist, do not just nail them.
Only use ACQ apprive fastners!
