Damaged Siding - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-02-2013, 08:33 AM   #1
Rewards Points: 252
Damaged Siding
Hello all, I made a mistake by pressure washing off the paint off of my 3 season sun room. The pressure washer damaged a few boards probably like 3 1'x8's. The boards are tongue and grove and are about an inch thick. So removing them and getting new ones are really not an option. Plus fixing I would thing would be cheaper and easier.
I started to sand them down to fix the issue but that is taking forever. I will probably keep sanding them down unless someone could suggest something easier?
The damage are just small little dents and really show through the paint.
Sorry I don't have a pic
jburchill is offline   Reply With Quote
Old 07-02-2013, 09:18 AM   #2
Rewards Points: 13,736
Without a picture where going to have to guess.
Once the paints sanded off I would try using Durham's Water Putty.
http://www.waterputty.com/
Or Bondo.
Old 07-02-2013, 09:32 AM   #3
Rewards Points: 252
Thanks for the reply, after I get the paint off I think sanding will fix the issue. I didn't really want to use putty to fix it.
What are your thoughts on a hand planer to smooth it out?
Old 07-02-2013, 12:38 PM   #4
Rewards Points: 252
I think i'm gonna go buy a belt sander and see if that works
Old 07-03-2013, 10:51 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,728
You are going to need a steady hand. You can very quickly take off a bunch of material with a belt sander.
I would start with a DA sander. It will be easier to blend.
Old 07-03-2013, 03:19 PM   #6
Rewards Points: 252
I started to fix the issue lastnight and the belt sand works pretty good. After I use the belt sander I use a palm sander to blend it in. its looking better now.
Siding mixing bski555 Building & Construction 3 07-07-2010 09:37 PM
Pressure washing painted houses nightman General DIY Discussions 6 02-05-2008 08:23 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
