-   -   Damaged Siding (http://www.diychatroom.com/f14/damaged-siding-182915/)
jburchill 07-02-2013 08:33 AM
Damaged Siding
11 Attachment(s)
Hello all, I made a mistake by pressure washing off the paint off of my 3 season sun room. The pressure washer damaged a few boards probably like 3 1'x8's. The boards are tongue and grove and are about an inch thick. So removing them and getting new ones are really not an option. Plus fixing I would thing would be cheaper and easier.
I started to sand them down to fix the issue but that is taking forever. I will probably keep sanding them down unless someone could suggest something easier?
The damage are just small little dents and really show through the paint.
Sorry I don't have a pic
joecaption 07-02-2013 09:18 AM
Without a picture where going to have to guess.
Once the paints sanded off I would try using Durham's Water Putty.
http://www.waterputty.com/
Or Bondo.
jburchill 07-02-2013 09:32 AM
11 Attachment(s)
Thanks for the reply, after I get the paint off I think sanding will fix the issue. I didn't really want to use putty to fix it.
What are your thoughts on a hand planer to smooth it out?
jburchill 07-02-2013 12:38 PM
11 Attachment(s)
I think i'm gonna go buy a belt sander and see if that works
Windows on Wash 07-03-2013 10:51 AM
You are going to need a steady hand. You can very quickly take off a bunch of material with a belt sander.
I would start with a DA sander. It will be easier to blend.
jburchill 07-03-2013 03:19 PM
11 Attachment(s)
I started to fix the issue lastnight and the belt sand works pretty good. After I use the belt sander I use a palm sander to blend it in. its looking better now.
