Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-11-2009, 12:11 PM   #1
Default damaged load bearing stud, next to a window
Hello, I have a unique load bearing stud problem. A very slow plumbing leak created a terminte problem in load bearing wall. The damage impacted two studs. 1 of these was been repaired by replacing the bottom portion with new wood and scabbing with a new section that sistered to the stud all the way to the bottom plate.
The other damaged stub is a real problem - it is on one side butted up against two additional studs which adjoin a kitchen window. The stud with real damage is the one on the outside from the window.
The other side of the damaged stud it is very close to plumbing (yes the plumbing that leaked) that goes into the slab. There is not enough room to scab with wood.
The wood actually seems very solid as the damage was caught early but it is very stained and there is definite surface terminte damage.
Can I cut the 2x4 out without issue without additional support on the wall (this is a downstairs exterior wall ). Then assuming I can remove it -
could I use a new section scabbed with a steel plate (maybe 1/4in)?
I think I'd have enough room to insert a 1/4"x 2" wide steel plate with screws to act as a scab.
Thanks in advance and all guidance appreciated.
dan
danf01 is offline   Reply With Quote
Old 10-12-2009, 08:02 AM   #2
Not quite sure what you are describing. A pic is worth a thousand words.
Tags
stub load wall
More On This Topic
Remodeling, whether it is in the garage or in the house is a huge undertaking. One of the easiest projects is building a non-bearing interior wall. The tools are basic, as are the needed carpentry skills. The condition of the floor and ceiling will... Read More »
Named after their tendency to excavate extensive galleries in wood beams, the carpenter ant rarely causes structural damage to a well maintained home. Still, it's important to prevent and repair any damage to wood caused by carpenter ants, so follow... Read More »
This is Rob McMahon with ExpertVillage. Now, with a framing gun, there is generally two different, two different types of nailing styles that you use. One is through nailing which is preferable in most situations because it gives you the most strength... Read More »
Installing a New U Joint
Installing a New U Joint by Expert Village
In this clip we're going to talk about the proper service procedure for removing and replacing a rear axle u-joint on a Ford Explorer. In this step we're going to talk about the proper service procedure for cleaning out our surface where our snap ring... Read More »
Hi this is Jon on behalf of Expert Village, in this video clip I will show you how to prepare our wall studs. On our Styrofoam installation our wall studs fall behind this diamond line. In addition the studs falls where the Styrofoam pieces fit together... Read More »
Replacement Window with nailing fin mjbcable Building & Construction 0 09-15-2009 03:40 PM
New Window in a Load Bearing Wall pleuraxeraphim Building & Construction 5 04-15-2009 09:08 PM
Cutting a stud on load bearing wall timw Remodeling 5 01-12-2009 03:55 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 05:44 PM
Framing a window in a load bearing wall Dom Carpentry 10 11-30-2007 05:57 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
