Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-09-2013, 11:37 AM   #1
Cutting window trim into a 45-degree angle
With my kitchen window, we wanted to encase it in trim, like a picture frame, and we cut the ends of each board into a 45-degree angle cut so they would fit together easily. I was planning to do the same thing for the trim on the front and back doors and the bedroom doors, since drywall wont really cut it. The problem is no electricity, so i cant use a chop saw, which would make things so much easier. We used a miter box with the window, and it was such a pain! Is there an easier way to do the cuts without electric?
TrailerParadise is offline   Reply With Quote
Old 01-09-2013, 03:11 PM   #2
Newbie Bill
Is there a neighbor nearby who would let you run an extension cord for occassional power uses?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 01-09-2013, 04:03 PM   #3
not one that is close enough. closest neighbor is about twenty feet away, but he hates me, so the next closest neighbor is about 150 feet away, too far for any extension cord. the only power we have is a generator, and we cant run it constantly for the time it takes to do trim
Old 01-09-2013, 06:24 PM   #4
Why not?
Unless your trying to do this at night there's nothing they can say or do about it.
Just do all your cuts at one time.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
mae-ling (01-09-2013), woodworkbykirk (01-09-2013)
Old 01-09-2013, 07:35 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
yup production stylel. its how i do it when im trimming new windows and doors.. all my mitres are precut. then i just trim stuff to lenght by cutting the square end . a slightly off square cut wont be nearly as noticable as a bad mitre cut after its caulked and painted
woodworkbykirk is online now   Reply With Quote
Old 01-09-2013, 07:43 PM   #6
take your measurements and cut them elsewhere, then go and nail them on.
princelake is offline   Reply With Quote
Old 01-10-2013, 04:35 PM   #7
Haverhill Trade 1965
Are you living in the house? If you are and there is no electricity there isn't much they could do about using an emergency generator.
Duckweather is offline   Reply With Quote
Old 01-10-2013, 04:37 PM   #8
No, we cant live there without electric and operating plumbing
Old 01-10-2013, 07:05 PM   #9
Generator?
scottktmrider is offline   Reply With Quote
Old 01-10-2013, 07:14 PM   #10
Davejss's Avatar
A pretty good miter box combined with a very good back saw should work just fine.
Davejss is offline   Reply With Quote
Old 01-10-2013, 09:27 PM   #11
you could try one of these
http://www.handandpowertoolshop.com/...FQGvnQodcwkA-Q
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 01-11-2013, 07:25 AM   #12
In a pinch I have used a builders square and my 6" cordless circular saw ( I call it a trim saw ..lol)
You can cut some clean 45's by just running the shoe along the edge of the square
Sean'o ATHS is offline   Reply With Quote
Old 01-11-2013, 09:02 AM   #13
Miter box works just fine. Its a pain in the rear.
Old 01-12-2013, 08:37 PM   #14
Your neighbor is already out of the picture so move the generator all the way to his property line and fire away. My chop saw is 15 amp, not sure if an inverter would work for this. I would say drop the money and get the electric turned on.
paintdrying is offline   Reply With Quote
The Following User Says Thank You to paintdrying For This Useful Post:
woodworkbykirk (01-12-2013)
Old 01-13-2013, 12:26 AM   #15
well once the power is finished i will get it turned on but thats gonna be a pretty good while from now. only room with receptacles is the kitchen and the power pole isnt even in the ground yet. and my neighbor has nothing to do with the generator, i cant use it for very long cause i cant afford the gas to run it. it uses 5 gallons of gas in just a couple of hours only running a lamp. hooking a tool up to it would probably take 5 gallons of gas in half an hour. last winter we used it during a 3 day power outage to run the tv and heater and spent $500 just in gas to keep it running. and that is not an exaggeration.
Tips for Cutting Baseboards and Door Trim hellothere123 Carpentry 25 10-20-2012 10:40 AM
Trim & Molding Meet at 90 degree wall cyager01 Remodeling 6 09-30-2012 11:00 AM
Need ideas for exterior window trim chrisngo Windows and Doors 1 01-17-2012 07:17 AM
Removing interior window trim paulyg Remodeling 2 09-21-2010 07:15 AM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
