Cutting Window Opening In A Door? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-13-2010, 12:26 PM   #1
cutting window opening in a door?
i have a beveled glass window for the solid, steel clad, walkin garage door. going to cut a 23x37" hole in door for window. i have one chance to get this right, or door is history, so i don't want to bunge it up. what saw & blade would work best to get a neat square hole cut in for this? i think a saber saw might not cut straight or square. a skill saw, with a guide?
ideas welcome.
thanks.
gene_champ is offline   Reply With Quote
Old 06-13-2010, 12:53 PM   #2
DIY staff
Rewards Points: 7,174
A skill saw with a steel cutting blade might work--it will depend on the core of the door--
A steel cutting blade is just a steel disk with a few heat relief slits cut into it(Menards has them in our area)--I've cut lots of steel up to 1/8 inch thick with a SkillSaw and a blade like that--An all steel(no carbide) fine toothed plywood blade also works.--Start slow and wait for the sparks--they don't really "cut' they melt the steel.
An angle grinder with a cut off wheel will also do the trick.
A set of sheet metal three blade shears (this removes a 1/8 inch strip) will work ,if the core of the door doesn't get in the way.
There are other ways,too. Some a bit dangerous--I'll leave those out.---Mike---
Old 06-13-2010, 01:03 PM   #3
Is this a door from the house to the garage ?
Or from the garage to outside ?
Old 06-13-2010, 08:04 PM   #4
jlhaslip's Avatar
Rewards Points: 2,140
The 'metal cutting' blade will overheat the metal and blister the paint. Don't ask me how I know this...
I would use a carbide toothed framing blade installed backwards (with safety glasses) to cut the hole. It has worked for me in the past.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
oh'mike (06-14-2010)
need recommendations for window replacement inside old door ilyaz Carpentry 4 04-30-2010 06:16 PM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
Items are prevent door from opening...what to do? foodiechick General DIY Discussions 11 04-24-2010 10:07 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 03:19 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
