Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-17-2009, 01:12 PM   #1
Default Cutting Trim around stairs
I'm trying to install some casing below the edges of the hand rail that I have on my stairs. Cutting the side peices seems fairly straightforward, but I'm having trouble trying to get the bottom peice (end of stairs below the rail) to match up to the side pieces. I've tried mitering but that doesn't seem to work. Due to the angle the side peices end up much lower down the wall than the end peice. Any suggestions?
Here is a picture to try to explain what I'm working with...
gobucks is offline   Reply With Quote
Old 03-17-2009, 02:33 PM   #2
Not so new
12penny's Avatar
gobucks.....not sure I can explain it here so I built you a mock up. Of course your dimensions will be different but you get the idea. Actually four pieces of trim, not two. Hope it helps.
12penny is offline   Reply With Quote
Old 03-17-2009, 03:27 PM   #3
Building codes guy, Mod
thekctermite's Avatar
You're dealing with a compound miter. You'll lay the casing flat on the miter saw and set the miter to the angle of the wall, then set the compound cut to 45 degrees. If you don't have a compound miter saw you'll need to rent or borrow one.
12penny's method will let you do it without a compound cut and just a miter, but will look a little less professional (albeit more DIYer friendly). No offense 12penny...That is a great mockup and is a nice thing of you to do that!
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 03-17-2009, 03:50 PM   #4
Although "12 pennies" idea will work. And qudos to him for taking the time to make a mock up for you.
It will be much faster and a cleaner look if you go with the compound cut.
The way I always did it is cut your two long boards first then connect them with the bottom short piece. That way you can sand the miters perfect.
Last edited by OutToPasture; 03-17-2009 at 03:51 PM. Reason: just looked at the mock up again that way wont work
OutToPasture is offline   Reply With Quote
Old 03-17-2009, 03:54 PM   #5
Sorry 12 but look at your piece #3 his railing has no horisontal spots on it except the bottom face. After he gets around the corner.
Solution= get yourself a compound miter saw or a contractor
Old 03-17-2009, 07:41 PM   #6
Thanks everyone - and thanks for the mockup 12penny.
Old 03-17-2009, 08:09 PM   #7
Newbie Bill
I have nothing constructive to add.
But I did want to say Holy Cow Batman, good job on the Extra Effort 12penny.
drtbk4ever is offline   Reply With Quote
Old 03-17-2009, 08:59 PM   #8
Not so new
12penny's Avatar
The way you always did it where? Go try it.
seriously, go try it.
I did tell him that his dimensions would be different than shown. Obviously the fit needs to be tweeked. This a DIY forum, without getting into the whole "what tools do you have thing" I offered advise anyone, regardless of his/her ability to pay $300 for a saw, could learn from.
And really, try to cut that joint. I've got two compound miter saws and neither of them can do it. The 45 compound miter cut is too long and will not mate to the short piece at the end of the wall. Something about changing planes. The only way to do it is to transition into it. If I'm missing something please post a picture. Never too old to learn.
Old 03-17-2009, 11:50 PM   #9
Old School
Willie T's Avatar
You can get what your are looking for if you are either using plain stock, or have the capability of cutting your own molding profiles.
The reason is shown here. There is no way around the fact that these are two different widths of boards.
It's an easy set-up and simple cut. But it takes two size boards to do it the way you seem to want to.
Even if you could use a router to cut some attractive grooves in plain stock, you will have to use a slightly wider (but not deeper) width groove on the end piece for them to match perfectly.
Willie T
Old 03-18-2009, 01:27 AM   #10
Woody
Phuture's Avatar
i have to agree with 12d. compound or no compound mitre. because of the angle the caseing comeing down the stairs is cut at you can't make this joint. if you want to dress up the hand rail your best bet would be flat material.
Phuture is offline   Reply With Quote
Old 03-18-2009, 01:33 AM   #11
Woody
Phuture's Avatar
come to think of it.....if you take 12penny's #3 piece and start the mitre for your front piece where #s 1'2' and 3 meet on the top' it would work nicely. a little tricky; but works.
Old 03-18-2009, 09:06 AM   #12
Not so new
12penny's Avatar
Its the only way. But I'm afraid we've lost the OP. Probably the best way to handle it would be to return it to the wall and not bother going around the corner.
Old 03-18-2009, 09:25 AM   #13
Thanks everyone. I'll give it a shot trying something along the lines of 12penny's mockup and let you know how it goes.
Old 03-18-2009, 10:31 AM   #14
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Nice Picture Layout
- Build Well -
More On This Topic
Hi! This is Bobby Hester on behalf of expertvillage.com. In this clip, we will be demonstrating the basic functions of a miter saw. A miter saw allows you to make perfectly accurate straight miter and bevel cuts time and time again. A straight cut is a... Read More »
Hi! This is Ed Reyes with Master Builders from Tampa, Florida. On behalf of Expert Village, this is how you use and maintain a miter saw. So basically the complete use of this machine involves your sliders, your back slider which slides back and forth... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an inside corner. Crown molding sits against the wall usually at a 38 degree or a 45 degree that depend on the type of... Read More »
Hi, this is Ed Reyes with Master Builders from Tampa, Florida. On behalf of Expert Village, this is how you use and maintain a miter saw. Now this particular saw features a compound saw which means two angle cuts at the same time. So we are going to cut... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip we will cutting our miters. On our diagram we see that each piece comes to a miter corner. This is more for ascetics then functionality. What we need to do is transfer these angled cut onto... Read More »
cutting door trim TTVolks Flooring 7 03-03-2009 10:51 AM
mahogany t&g porch floor, trim, stairs questions schmolze Carpentry 1 09-21-2008 11:13 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 05:19 PM
baseboard trim gaps on stairs beppygirl General Discussion 8 02-24-2008 03:31 PM
Transitioning painted stairs to hallway and trim...HELP naromli Painting 2 01-26-2008 03:21 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
