Cutting Tile..... - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 11:04 AM   #1
Cutting tile.....
I need to cut thick tile that I have in my bathroom. It's on a slanted roof and I need to shave off about 2 inches of tile by about 8 inches long to fit a new fan/light in the shower. I have a Rotozip tool. The only option I have seen is to buy a $40.00 bit that will cut the tile. Do I have any other options?
chipbott is offline   Reply With Quote
Old 06-03-2011, 11:16 AM   #2
Old School
Willie T's Avatar
I think the diamond circular saw blade for the Roto Zip is a little bit cheaper. Cuts good. But you need to have the 90* angle head for the tool.
Willie T
Old 06-03-2011, 04:53 PM   #3
they sell 7" diamond blades for circular saws. home depot and lowes carries them. 20-25 dollars a 4 inch one for a grinder is about 12.00
Old 06-03-2011, 05:11 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Depends on the tile used.
What size is the tile?
XXX
Old 06-03-2011, 08:57 PM   #5
They are the standard 4 inch square tile but probably 1/4 inch thick.
Old 06-04-2011, 12:35 AM   #6
Rewards Points: 282
those are super standard color/pattern. my bet is that if you work slowly and scrape the grout out first that you can pop those off with no damage.
far easier to cut when off the wall and you will spend weeks cleaning tile dust out of everything if you cut in place.
i bet you can source those at one of the big box stores though....
jcrack_corn is offline   Reply With Quote
Old 06-04-2011, 08:19 AM   #7
If I needed the whole tile out I would most certainly work from the grout line instead of cutting the tile. Unfortunately I only need to take out about half of the tile, taking the whole tile would be too much.
Old 06-04-2011, 09:21 AM   #8
Newbie Bill
Rewards Points: 520
chibott, I think jcrack_corn was suggesting popping the entire tile out, cutting it, and then reinstalling it.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 06-04-2011, 09:27 AM   #9
Yes. You are correct. I read it again after. I will more then likely do that. Thanks all for your input. Thanks also to DIY for these forums. What an awesome resource!
Old 06-04-2011, 09:28 AM   #10
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Oops, deleted. I type too slow.
Cutting ceramic tile away from bathtub Tomgrillo Tiling, ceramics, marble 2 03-24-2011 12:04 AM
cutting round lines on ceramic tile wombosi Flooring 3 06-21-2010 06:58 PM
Cutting tile on a diagonal kntry Building & Construction 7 09-09-2009 11:52 PM
cutting mosaic tile amakarevic Flooring 6 06-04-2008 05:02 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
