Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-02-2011, 10:30 AM   #1
Cutting through sill plate...
Hi
Is it okay to cut through my sill plate in my kitchen to install an electrical box. I would like all electrical boxs to be the same height.
Thanks Adrien
adrien2 is offline   Reply With Quote
Old 10-02-2011, 11:13 AM   #2
Moderator
kwikfishron's Avatar
What does the sill plate have to do with the electrical box?
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 10-02-2011, 11:26 AM   #3
"Nail-Bender"
"kwiK'
Sounds like they want to come up through the basement/crawlspace -
floor below???
Maybe they mean "studs"?
Maybe they found "blocking" in the wall? (they think the term is "sill-plate")
I don't know!?!
rossfingal
rossfingal is offline   Reply With Quote
Old 10-02-2011, 12:52 PM   #4
There is block and there is a 2 x 10 that is sitting on the top on the block. On top of the 2 x 10 there is a wall. So what is this called? and is okay to cut a openning for an electrial box in the 2 x 10.
And by the way, I didnot double post, I click of submit twice. Since I could not delete one, I have no option by to leave it.
Old 10-02-2011, 01:17 PM   #5
"Nail-Bender"
Oh, I see -
You're talking about adding/moving the electrical box on the on the left
side of your picture - to line up with the box on the right?
Cut a hole through the 2 X 10; so you can install another box?
I think that's what you're saying.
If you're going to install a "GFCI" in the box that you're going to add -
should be a 4" by 4" by 1 1/2" - not a switch-box.
It looks like you can do that -
Remember - if you have to extend the wiring - splices should only occur in boxes with access - cover-plates on boxes closed off.
Don't worry about "Double-posting" - just a reminder.
rossfingal
Old 10-02-2011, 02:07 PM   #6
renovation contractor
Is it a split level house?
B.D.R. is offline   Reply With Quote
Old 10-02-2011, 02:38 PM   #7
Super Moderator
Sure looks like it to me---
Old 10-02-2011, 03:03 PM   #8
"Nail-Bender"
Yes, could be split-level (I grew up in one) -
2 X 10 - "rim joist" - OK, to put a hole for electrical box through it? -
Maybe, what do you think?
rossfingal
Old 10-02-2011, 03:19 PM   #9
Super Moderator
It's supported by a knee wall---4x4 hole? I'd do it.
Old 10-02-2011, 03:36 PM   #10
"Nail-Bender"
That's what I thought.
"Rim", Band", "Header" joist (too much nomenclature) -
At least the "op" isn't talking about 4 inch, notches in other areas!
"Nuff" said -
Thanks for the input!
Happy fall! (It's October already!)
Happy Halloween! (Those darn "Pagans"!)
rossfingal
Old 10-02-2011, 09:15 PM   #11
Too Old
From what you are trying to say it sounds like you can go for the cut
but from I see it looks like the outlet is high on the left wall, but pictures are not scale.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Repair/replace sill plate and joist ends heybales Building & Construction 5 02-16-2013 11:33 PM
Replace Sill Plate to Basement Block Wall - No anchor bolts DoItMyselfToo Building & Construction 4 09-10-2011 04:07 PM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 09:08 PM
How short can sill plate pieces be ? tuckerz Building & Construction 2 10-04-2009 04:41 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
