Cutting Stair Stringers - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 03:58 PM   #1
liscenced electrician
Rewards Points: 538
cutting stair stringers
Im trying to lay out some stair stringers and im pulling my hair out. The problem is that the stringers are right at the length where 20' will work, but i don't have room for waste
At first i was laying the stringers out so they would be flush with the existing 2x12 and then put plywood roofing an 3" of decking on, so its all flush on the first step. The problem is with cutting 3 1/2 off the top step, it barely leaves anything to attach to the 2 x 12. Now im thinking i should make the first step lower, so you step off the deck down onto the first step.
Can anyone help me lay this out?
The concrete pad is 170" to the edge of it, so i figure to the front of the step it should give be 185". It will be 129 1/4 to the top of the decking, although at the moment, just the roofing is on
jimmy21 is offline   Reply With Quote
Old 11-30-2011, 04:07 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 304
You will have 17 risers divided into 129.25" the run will be 10 inches.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-30-2011, 05:04 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
F.Y.I code says no one step can vary more than 3/8" from the others. Don't forget to allow the thickness of you tread material on the first tread cut (bottom).
titanoman is offline   Reply With Quote
Old 11-30-2011, 05:48 PM   #4
Rewards Points: 171
Try this stair calculator
http://www.blocklayer.com/Stairs/StairsEng.aspx
paul100 is offline   Reply With Quote
Old 11-30-2011, 06:27 PM   #5
Rewards Points: 538
then my stairs would be in the dirt with the front of the first step touching the concrete.
I got it figured out though. Subtracted 8 1/2 (7 inch step plus 1 1/2 tread) from my original 129 1/4 calculation, to give me 120.75. divide that by 17 and i ended up with roughly 7 3/32. To give me the distance needed to get on to the concrete i went with 11 1/2 runs. This made the back of my stringers clear the concrete by 8 inches or so. Stuck them in place, and they look perfect. Glad it worked out, cuz i was sure pulling my hair out earlier. The real problem i was having was that i kept thinking my 20' 2x12's were too short
Old 11-30-2011, 06:53 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,116
that must some wacky american code, in canada its no more than 1/8 variance between risers.. if you have to make it up you add or subtract 1/16 over 6 rises, cant do it all at once
also with a total rise of 129", you have to have a landing.. code requires a resting point as soon as a flight of stairs has 13 or more risers
woodworkbykirk is offline   Reply With Quote
Old 11-30-2011, 06:58 PM   #7
Disabled wood vet
titanoman's Avatar
Canada must have the wacky codes . Half the houses in America have a 9' basement which is 15 risers with no intermediate landing. Thats just silly.
Old 11-30-2011, 07:11 PM   #8
kwikfishron's Avatar
Rewards Points: 420
You're only required to have a landing at the 12’ mark of rise here, regardless of the number of steps.
kwikfishron is online now   Reply With Quote
Old 11-30-2011, 07:15 PM   #9
Disabled wood vet
titanoman's Avatar
Originally Posted by kwikfishron View Post
You're only required to have a landing at the 12 mark of rise here, regardless of the number of steps.
Now that sounds more like it.ki
Old 11-30-2011, 07:28 PM   #10
recently retired
Rewards Points: 280
There are a number of problems here-
The pad was poured before the stair was drawn out and so isn't in the right place.
A 20' stringer is too long for a single flight of stair, it will be bouncy and perhaps over stressed.
The sub-tread, roofing and 3 1/2" tread material? What's going on?
There should be a landing on this stair.
That'll do for now, do you have a jack hammer?
Keith Mathewson is offline   Reply With Quote
Old 11-30-2011, 08:13 PM   #11
Disabled wood vet
titanoman's Avatar
Well of course you can use a mid-span post if theres no wall to attach to (?).
The mid-span landing? No reason. And then they would really miss the concrete.
And I don't get the plywood or roofing either.
Old 11-30-2011, 08:30 PM   #12
Rewards Points: 538
I'm not worried about supporting mid span, that's not. Problem. But having a landing required would suck. The concrete is plenty big enough so I have room to extend farther. It just couldn't be too short. The roofing is because this is a combination carport and deck. It has torch down roofing and then I'm putting 2x4 sleeepers down and then screwing the deck to the sleepers, to not puncture the roofing.
The only reason I'm building a deck/stairs is the building inspector said I need permanent stairs up to my storage trusses. He said I have too much headroom up there and it therefore requires permanent stairs. The original pull down stairs don't count.
Old 11-30-2011, 08:30 PM   #13
recently retired
Rewards Points: 280
Please tell me how a mid span post counteracts lateral forces?
And That's why there are building inspectors
Old 11-30-2011, 08:33 PM   #14
Disabled wood vet
titanoman's Avatar
Not a lot if one of the stringers isn't anchored to a wall.
And it's totally legal in california,/everywhere.
Old 11-30-2011, 08:36 PM   #15
any person walking up or down a flight of stairs will develop a memory in regards to how much to raise their foot to walk up the stair comfortably,, any more than 3/16" becomes very awkward and makes it more likely for the person to trip.. hence our code of max riser variance of 1/8"
what are you framing your stairs with to have more than 13 rises in a straight flight of stairs and not have issues with the stair sagging our bouncing? 2 ply lvl's
we have much stricter codes in a number of areas for different trades
one of the scariest ive heard is regarding your electrical,, cant remember teh exact distance but you can have as many outlets as you can fit within so many feet. here you cant have more that 12 outlets or light boxes per circuit. with out code electrical fires are far less likely to happen as
Help with cutting stair stringers dukes32 Carpentry 7 11-17-2012 10:56 AM
Cutting stair stringers for OLD basement steps 4just1don Building & Construction 1 08-11-2009 06:21 AM
Stair Stringers mntnvew Carpentry 14 04-14-2009 12:09 PM
cutting stringers!!!! wombosi Building & Construction 6 02-20-2009 05:34 PM
Fastening stair stringers bacdef Carpentry 6 08-07-2008 09:31 PM
