Cutting Rafter - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-22-2009, 11:30 PM   #1
Smile
Cutting rafter
The house has a totally flat roof covering a front porch (9 by 24). I wish to change the pitch from zero to a 4/12 to match the pitch on the existing gable roof. My problem is I don't know, without trial and error, how to cut the front and back ends of the rafters to obtain the correct slope or pitch. I know I can make a jig which is 4 in high and 12 in long or any multiple of those number to give me the pitch but as I said how do I figure the angle on the front and back end of the rafters so that will lay correctly on the existing roof. Hope I have explained this problem to everyone's satisfaction.
66mustang is offline   Reply With Quote
Old 03-22-2009, 11:34 PM   #2
What slope will the back end be tied into?
A flat wall?
Angled roof?
Old 03-23-2009, 12:01 AM   #3
knowsomethings
It would be helpful if you could post a picture. If you are simply extending the gable out over the porch, the ridge (top) cut (angle in degrees) should match the existing rafters. The seat cuts (top of wall) will be 90 degrees off the ridge cut. The length will all depend on if the porch headers line up with the top of wall. There are so many questions that a good answer cannot be given without pics.
Greg
runout is offline   Reply With Quote
Old 03-23-2009, 12:15 AM   #4
Do a search on how to use a Framing Square.
hayewe farm is offline   Reply With Quote
Old 03-23-2009, 01:57 AM   #5
Tom Struble's Avatar
Rewards Points: 2,002
string a line that represents the bottom of you rafter and use a bevel gauge to get the angles you need
Tom Struble is offline   Reply With Quote
Old 03-23-2009, 08:07 AM   #6
an angled roof. Thanks.
Old 03-23-2009, 01:04 PM   #7
the Musigician
DangerMouse's Avatar
tom, please go back and read bearly bearable thread.
DM
Old 03-23-2009, 01:48 PM   #8
ok pal
Cutting a bird's mouth cut in a rafter? darsunt Building & Construction 4 02-20-2009 09:22 AM
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 07:03 PM
rafter questions - structural rtoni Carpentry 11 09-13-2007 06:40 AM
