Cutting Plywood. - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 02:34 AM   #16
I think its about time I own a Jigsaw anyway, so Im going to buy one tomorrow.
ReefGuru is offline   Reply With Quote
Old 07-17-2012, 09:25 AM   #17
Rewards Points: 258
I have a B&D 2 speed and it works fine. Supposedly comes with blades so you won't have to buy http://www.harborfreight.com/catalog.../category/684/
puttster
puttster is offline   Reply With Quote
Old 07-17-2012, 01:24 PM   #18
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
There is a tool out there to do just about and operation and any quality from "That'll do" to That's perfect"
The big shops use a CNC router fast efficient and perfect.
The DIYers would use the tool he has or the tool suited for the quality cut he needs.
1] A router is going to give the cleanest cut but requires a jig and set up
2] A cordless circular saw is the next best with a relatively clean cut, can be eyeballed and cut from both sides of the board.
3] A jigsaw is also effective but gives the roughest cut.
Ask yourself "What tools do I have...what quality cut do I need and how fast do I want to do it?"
Mike
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Old 07-17-2012, 06:40 PM   #19
Mike
Thanks Mike. Yes, I know about CNC machines. Ive seen them used with acrylics for a large amount of aquarium parts.
I went out and bought a Jigsaw today. It comes with a t-shank blade. Its a rough cutter but I'll sand the hole down afterwards. Should be just fine.
Old 07-17-2012, 06:53 PM   #20
In a little over my head
Rewards Points: 706
The trick to using a jig saw is good blades. The Bosch t-shanks are hard to beat. Most of the rest stink. Oh yeah, once the good blades get dull, they stink too.
Practice plunge cutting on a piece of scrap. Once you get the hang of it, you'll never drill a starter hole again.
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
ReefGuru (07-18-2012)
Old 07-17-2012, 06:54 PM   #21
Thanks for the tip.
Old 07-17-2012, 06:59 PM   #22
kwikfishron's Avatar
Rewards Points: 174
A new fine tooth metal cutting blade will give you a much cleaner cut and will work fine for what you're doing.
kwikfishron is online now   Reply With Quote
Old 07-17-2012, 07:00 PM   #23
Originally Posted by kwikfishron View Post
A new fine tooth metal cutting blade will give you a much cleaner cut and will work fine for what you're doing..
I wish I would have known. Maybe i'll order one now and wait for it. I really wanted to finish this today.
Old 07-17-2012, 07:02 PM   #24
the Musigician
DangerMouse's Avatar
If you tape the area with masking tape it'll keep the chipping to a minimum.
Remove tape immediately after cutting.
DM
Old 07-17-2012, 07:06 PM   #25
Rewards Points: 174
Why would you need to order it?
I live in the middle of nowhere and still have a hardware store close by.
Old 07-17-2012, 07:53 PM   #26
General Contractor
I would plunge cut with my circular saw without overcutting and finish with my jigsaw. Hand saw will work in place of a jigsaw if you don't have one. And it is harder to make a straight clean cut with a jigsaw than a circular saw.
KennMacMoragh is offline   Reply With Quote
Old 07-17-2012, 09:31 PM   #27
Rewards Points: 258
Great choice. To cut your 6" hole, I doubt you would have been happy buying a circular saw...
Old 07-18-2012, 12:22 AM   #28
I own a circular saw. I made about 12 cuts with it today. After all this time owing it, I finally found the sweet spot to line up the blade perfectly. Ive always thought the saw was just messed up but Ive finally got it.
The Following 2 Users Say Thank You to ReefGuru For This Useful Post:
mae-ling (07-18-2012), PaliBob (07-18-2012)
Old 07-18-2012, 12:31 AM   #29
Rewards Points: 2,210
Both have there place but for the very occasional use I'd go with a jig saw. YOu can cut straigth with a jig saw but it is hard to cut (but not impossible) curves with a circular saw.
mae-ling is online now   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Painting exterior plywood wall sheathing hiphi45 Building & Construction 2 12-24-2011 01:12 PM
Installation options for plywood underlayment? ScooberJake Flooring 0 09-03-2011 12:00 PM
Staples or screws on plywood subfloor? And other questions.... howdihi Flooring 1 08-18-2011 09:50 PM
Tile over plywood? Thurman Flooring 3 07-12-2009 10:05 AM
