Cutting Pegboard - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-22-2012, 06:18 PM   #1
Rewards Points: 1,584
Cutting pegboard
I have a pegboard I need to cut to a specific size to mount.
What is the best way to cut it?
Can I cut it with a table saw or would that chew it up real bad?
It's a bit too thick to score with a razor blade I think.
miamicuse is offline   Reply With Quote
Old 02-22-2012, 06:29 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
1/8 or 1/4?
Table saw is fine.
Hold it down good.
titanoman is offline   Reply With Quote
Old 02-22-2012, 06:38 PM   #3
1/4".
I tried using a diamond blade on an 4.5" angle grinder and it got hot with a burnt smell fast. Besides it will take forever to do 8 feet of it.
I will try the table saw tomorrow, for some reason I thought a wood blade will chew it up bad.
Thanks.
Old 02-22-2012, 07:07 PM   #4
Hell of a fella
Rewards Points: 27
circular saw with a plywood blade. the fine teeth will make for a nice clean cut
DrumBum is offline   Reply With Quote
Old 02-22-2012, 07:51 PM   #5
Rewards Points: 6,652
Table saw with a fine tooth blade, that is used for paneling cutting.
Old 02-22-2012, 07:53 PM   #6
Ironlight's Avatar
Use whatever blade you have in the table saw and just go nice and slow, finished side up. Going slow is the same as using a blade with less teeth, lol
Ironlight is offline   Reply With Quote
Old 02-22-2012, 08:39 PM   #7
Disabled wood vet
titanoman's Avatar
Never thought about it like that before.
Good one.
Old 02-24-2012, 12:14 AM   #8
A table saw would be perfectly fine. I used to make these cuts at home depot all the time.
diyjohn1234 is offline   Reply With Quote
Old 02-25-2012, 11:46 PM   #9
Rewards Points: 35
I've cut a bunch of peg board with my table saw. A circ saw would work fine too - if you are working with a large sheet, it can be clumsy on the table saw by yourself.
KatHelms is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Cutting Duct ADKstorm HVAC 10 01-23-2011 02:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Cutting in to baseboards? windowguy Painting 9 02-08-2009 10:20 AM
Cutting Board DaveSteel Carpentry 1 02-21-2008 10:38 AM
