-   -   Cutting pegboard (http://www.diychatroom.com/f14/cutting-pegboard-134676/)
miamicuse 02-22-2012 05:18 PM
Cutting pegboard
3 Attachment(s)
I have a pegboard I need to cut to a specific size to mount.
What is the best way to cut it?
Can I cut it with a table saw or would that chew it up real bad?
It's a bit too thick to score with a razor blade I think.
titanoman 02-22-2012 05:29 PM
1/8 or 1/4?
Table saw is fine.
Hold it down good.
miamicuse 02-22-2012 05:38 PM
3 Attachment(s)
1/4".
I tried using a diamond blade on an 4.5" angle grinder and it got hot with a burnt smell fast. Besides it will take forever to do 8 feet of it.
I will try the table saw tomorrow, for some reason I thought a wood blade will chew it up bad.
Thanks.
DrumBum 02-22-2012 06:07 PM
circular saw with a plywood blade. the fine teeth will make for a nice clean cut
gregzoll 02-22-2012 06:51 PM
Table saw with a fine tooth blade, that is used for paneling cutting.
Ironlight 02-22-2012 06:53 PM
Use whatever blade you have in the table saw and just go nice and slow, finished side up. Going slow is the same as using a blade with less teeth, lol
titanoman 02-22-2012 07:39 PM
Never thought about it like that before.
Good one.
diyjohn1234 02-23-2012 11:14 PM
A table saw would be perfectly fine. I used to make these cuts at home depot all the time.
KatHelms 02-25-2012 10:46 PM
I've cut a bunch of peg board with my table saw. A circ saw would work fine too - if you are working with a large sheet, it can be clumsy on the table saw by yourself.
