Cutting Out For Outlets/switches With Panneling - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-19-2009, 09:50 AM   #1
Cutting out for outlets/switches with panneling
I am about to install OSB on the interior walls of my new workshop.
My question is: Because I have several single and double outlet boxes in my new workshop, what is the best/easiest way to cut out the holes in the OSB over the outlet boxes ? Is there a router bit that can use the inside of the box as a guide to cut the OSB to fit over the box? I think there is a similar method that can be used with drywall, but I am not sure if there is a way to do it with wood panels. I think if I try to measue over and cut the holes before I put the panel up, I will miss the box enough to have problems (extra time/frustration/waste). I have experienced this with drywall.
Roy Rowlett is offline   Reply With Quote
Old 08-19-2009, 09:57 AM   #2
the Musigician
DangerMouse's Avatar
2 hard drive magnets and some glue dots work well, even for wood. glue dot one magnet on each corner of your box, set wood up in place, then find magnets with nail or washer, etc. this will give you the location very close to exact. never seen a bit that does what you ask, but there may be. at the very least, it's a good idea!
DM
Old 08-19-2009, 10:45 AM   #3
By "hard drive magnet", do mean a magnet off of a computer hard drive? I am ignorant about what that is or how to find it.
Old 08-19-2009, 10:55 AM   #4
the Musigician
oops, sorry about that chief. yup, any dead hard drive you can tear open and grab the magnets from. most people have these magnets and don't know it. yer sort of new here, so maybe you haven't seen me talking about them. those darn things come in HANDY, let me tell you!
any strong magnets will work though, hdd's are just an easy source, and they're flat. i use the glue dots because i'm using plastic boxes, if you use metal, just stick them on and use another metal box on the outside to draw around. it will "center itself" to the correct area that way. *good luck*
DM
Old 08-19-2009, 11:01 AM   #5
zpm
yeah, right
Here's a way. Never tried it, but I think I will on my next project.
http://www.dannylipford.com/diy-home...-outlet-boxes/
Now you have a legit excuse for carrying lipstick in your tool belt.
There's also some templates you attach to the box and it will mark the sheet. I don't they they would work well on OSB.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 08-19-2009, 11:01 AM   #6
the Musigician
if you go to get one, they're usually glued to a metal plate with mounting holes. you can bend the metal slowly (i use vise and pliers) to release the glue and get just the magnet that way.
i also use them still glued to screw to the side of my workbench to hang tools i use all the time from. always amazed how much weight they will hold.
DM
Old 08-19-2009, 11:18 AM   #7
zpm,
Thanks, I 'll keep the lipstick with my tampons.
Old 08-19-2009, 11:55 AM   #8
Registered User
Termite's Avatar
The lipstick trick works as good as anything out there. I highly recommend it.
Old 08-19-2009, 01:16 PM   #9
the Musigician
sure it works, but you have to clean the goop off the box, then off your hands, and tools... i tried it once and i'm just too messy i guess.
and it stinks too...*phew* ...or is that just me that hates the smell of that stuff? reminds me of kissing grandma....
DM
Old 08-19-2009, 02:21 PM   #10
Registered User
Termite's Avatar
DM there are lots of ways to skin a cat.
Old 08-19-2009, 02:26 PM   #11
the Musigician
sure, but the cats still don't like it....
DM
Old 08-19-2009, 03:41 PM   #12
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
DM
The Irfanview logo cat doesn't seem to like it
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-19-2009, 03:55 PM   #13
General Contractor
I usually measure over for the boxes but there are easier ways to do it. The lipstick trick works fine if you have it on hand, if you don't want to use lipstick you can use chalk (they do sell it in a half oval shape for this purpose. There are also a variety of inserts on the market that install into the box and leave pin pricks in drywall. I don't know how well they would work in OSB. Rotozip does make a wood cutting bit and it works OK on 1/4" panels but 7/16 OSB may burn it and/or the rotozip up. If you go that route you will still need to measure to the center of the boxes so you know approx where they are (or use DM's magnet trick) as it will be harder to locate where they are on the thicker panels vs drywall or 1/4" panels.
ARI001 is offline   Reply With Quote
Old 08-19-2009, 04:16 PM   #14
the Musigician
once, the only thing i could find on hand was some 'water based personal lubricant'. lol
i smeared a little on the box and it worked ok. but same as the lipstick, i had to clean up the excess before i could wire.
but hey, it worked for the one panel i had to do. at least it didn't smell like grandma kisses....
DM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Cutting Duct ADKstorm HVAC 10 01-23-2011 02:30 AM
Cutting a beam flange devlin1k Building & Construction 17 02-13-2009 04:24 PM
Cutting in to baseboards? windowguy Painting 9 02-08-2009 10:20 AM
Cutting Board DaveSteel Carpentry 1 02-21-2008 10:38 AM
