-   -   Cutting Out Built In Shelves (http://www.diychatroom.com/f14/cutting-out-built-shelves-155395/)
McStella 08-31-2012 10:07 AM
Hi All!
I'm new here so hopefully I haven't missed this answer!
We have a wood burning fireplace with heatolaters in our living. We just moved in in Feb. Around the fireplace are built in shelves. I'm not in love with them but I don't hate them enough to take them all out. There are shelves directly above the fireplace- instead of a mantle essentially, that I do want to partially remove. We want to put our TV above the fireplace. There are nine cubby holes type of thing above the fireplace. I'd like to open the entire space and put in one shelf that spans the top of the fireplace so that the TV can sit on the shelf.
I'm looking for advice on how to cut out the original shelves. Can I use a jigsaw and carefully cut them and then patch the wood? And then how to do I install the shelf at the bottom?
Thanks!
joecaption 08-31-2012 02:37 PM
Without a pictre impossible to even guess.
McStella 08-31-2012 10:11 PM
1 Attachment(s)
Attachment 56671
This is what they look like. I want them all gone and then put in a shelf about six inches from mantel to place tv on.
oh'mike 08-31-2012 11:10 PM
Un-build them---remove the top trim---figure out the order that the parts were installed and disassemble it---no saw needed--
GBrackins 09-01-2012 12:26 AM
I take it you are talking about a flat screen tv over the fireplace. Check your warranty for the tv, I believe you're going to find it will be voided for this type of installation since the heat from the fireplace affects the electronics. I know, I know you see it done everywhere ...... plus its bad on your neck trying to look up
if you must ...... make sure you put a deep mantel over the fireplace in an attempt to direct the heat away from your tv.
my humble thoughts .....
Good luck!
