Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-04-2011, 09:53 PM   #1
Cutting out bottom plate for new door in existing partition
I'm installing a standard inside door along an existing interior wall. The wall is bare with 2x4's sixteen on center. I've removed one 2x4, leaving the beginnings of the new door frame.
What is the best way to saw the bottom plate without cutting through the subfloor? My circular saw would leave some board sticking out on either side.. is this a job for a hand saw or is there a better way?
sheslostcontrol is offline   Reply With Quote
Old 01-04-2011, 09:55 PM   #2
Hand saw or reciprocating saw.
jlmran is offline   Reply With Quote
Old 01-05-2011, 06:57 AM   #3
Framing Contractor
Is this a bearing wall?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-05-2011, 08:18 AM   #4
A door a day is all I ask
TheDoorGuy's Avatar
Sounds like you do not yet own a sawzall (reciprocating saw).
This job would be a great excuse for you to buy one!
You will find many uses for it in the future.
As Joe mentioned above, make sure that you use proper framing techniques
to support the load above.
Richard The Door Guy
TheDoorGuy is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
attach bottom plate to exizting slab Constant Improvement Building & Construction 1 02-04-2009 01:36 PM
Boring holes in a load-bearing bottom plate benjamincall Building & Construction 22 01-21-2009 10:05 PM
Rewiring old house, Hit brace in outside wall, Safe to drill through Bottom Plate. twilightcall Electrical 2 06-30-2008 12:36 AM
basement renovation yummy mummy Remodeling 156 05-08-2007 11:15 AM
