Cutting Opening In Hollow-Core Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 05:05 PM   #1
Rewards Points: 12
Cutting Opening in Hollow-Core Doors
I need to pick your brains regarding my options on cutting out a rectangle opening in a 1 3/8" hollow-core door. The opening will replaced with a plexiglass panel. I only need advice on making the opening, the rest I can handle.
My thoughts are:
1) needs to be a precision cut made through both sides of the door at once.
2) trim will NOT be covering the cut, so I need as little damage as possible.
3) the material is rather flimsy when unsupported during the cut.
4) a jigsaw blade's up/down action would probably make a mess of the underside as it pulls/pushes the flimsy unsupported underside.
So, what if I setup 4 rails [guide template], make a pilot hole in the middle, and use a router w/ a straight 2 1/2" bit, dropping it in the pilot hole, then go around the perimeter against the guides. The corners will be slightly rounded, but that is easily cleaned up with a hand saw.
I have basic skills with a router, but my lack of experience has more to do with "Is this the correct tool and will it do what I think it will do in this application"
Will this work? Do you have a better idea/tool?
fyi, there are 12+ doors, so a template/jig would seem to be in order.
8888 is offline   Reply With Quote
Old 04-02-2012, 05:10 PM   #2
DIY Enthusiast
sublime2's Avatar
How about this to cut the holes?
http://www.diychatroom.com/f29/oscia...i-tool-120729/
Many seem to swear by it!
sublime2 is offline   Reply With Quote
Old 04-02-2012, 05:16 PM   #3
Civil Engineer
Rewards Points: 4,514
A router with a long, straight carbide bit will work fine. As you noted, the corners will be rounded. Make sure you go the correct direction around the jig, else you will get an inferior cut.
Old 04-02-2012, 05:30 PM   #4
DIY Enthusiast
sublime2's Avatar
Which is counter clockwise......
Clockwise,it can run away from you.
Old 04-02-2012, 05:46 PM   #5
Rewards Points: 12
Wow, I never thought about the direction! Great heads up to Daniel and sublime2!
So you feel this will give me a nice clean cut edge and not get hung up on the inner material?
Old 04-02-2012, 05:49 PM   #6
DIY Enthusiast
sublime2's Avatar
Router will run through it like butter with the bit suggested.
Even more reason to hold on to the router firmly and take your time.
The Following User Says Thank You to sublime2 For This Useful Post:
8888 (04-02-2012)
Old 04-02-2012, 06:52 PM   #7
Civil Engineer
Just a word of advice, you will be using a deep bit, so you are best off with a 1/2 inch collet. The cardboard material inside the door will not slow down a decent router, and you can get a great cut. Finishing the corners to get as good a cut is not so easy, I think I would finish the corners with a very sharp chisel.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
8888 (04-02-2012)
Old 04-02-2012, 09:28 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
a router with a proper jig set up will give the best results.. ive done this with a circular saw using a shoot board with no issues. had to do it on 5 doors for a vet clinic we built 2 years ago
an oscilating tool isnt the correct tool for the jobs.. its a specialized tool for specific types of cuts..
woodworkbykirk is online now   Reply With Quote
Old 04-03-2012, 09:03 AM   #9
Rewards Points: 2,202
Done it once with a circular saw. Knew that the way I was trimming it would hide any small irregularities.
mae-ling is offline   Reply With Quote
Old 04-03-2012, 09:33 AM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
If you are not trimming the opening, how will you hide the cardboard filler inside the 2 face panels?
Coastal South Carolina
Old 04-03-2012, 09:38 AM   #11
DIY Enthusiast
sublime2's Avatar
I'd also like to know this for future reference if I should tackle something like this.
Old 04-03-2012, 01:33 PM   #12
Rewards Points: 12
Not sure you understand the process.
Once the opening is created, there is no longer any support at the opening, so filler lumber must be inserted and glued INSIDE the opening perimeter. This is for support only and does not cover the router cut, as it is inside the door.
The Plexiglas will float centered in the opening, held in place by trim whose ONLY job it is to hold the plexiglas in place. This trim will also not cover the router cut.
So this is why my original question was "how to make an accurate CLEAN cut". Bad cut = lots of post finishing work, Clean cut = very minimal post finishing work. 12+ doors x 2 sides is a lot of unnecessary work!
Old 04-03-2012, 08:02 PM   #13
In a little over my head
Rewards Points: 706
12 doors and a clean cut means router and a jig. I don't think you'll need to, but scoring the veneer will further prevent chipping. Will the plexiglas holding trim cover the end grain? You might be able to find a molding profile that holds the window and trims the opening.
http://www.template-services.com/Pro...%20Corners.htm
ratherbefishing is offline   Reply With Quote
Old 04-04-2012, 12:03 AM   #14
1) both sides at once? Transfer your marks with a Tsquare and use a plywood blade
2) Why no trim? A couple of grooves in a piece of 1 3/4" to make a frame that will finish off the cut edge and provide stability and rigidity
3) Shouldn't be a problem with a saw
4) Don't use a jig saw!
mrgins is offline   Reply With Quote
Old 04-08-2012, 11:34 PM   #15
Missouri Bound's Avatar
Most hollow core doors (luan)can be cut with a straight edge and a razor knife.
Do you want it your way or the right way?
reusing hollow core door as desk, sanding down hinge spots? bonanz Carpentry 20 02-06-2012 01:03 AM
Cutting Trim and Hanging Doors ws450r Carpentry 8 12-28-2010 03:54 AM
Replacing hollow doors with 6 panel eehammar Remodeling 2 02-16-2008 02:27 PM
Cutting cinder block for a large door opening joeyb Building & Construction 2 02-10-2008 01:00 PM
Hanging doors on drywalled and finished opening dk_99 Building & Construction 9 12-31-2007 10:34 AM
