Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-06-2009, 11:42 PM   #1
Default Cutting into 2 x 12 on Load Bearing Wall
I have a 9ft opening from the living room to the dining room. My wife wants the doorway arched some. To do this, I would need to cut about 7 inches into two 2 x 12s at the center then slope the cut to the edges. So my question is since this is a load bearing wall should I cut into the 2 x 12s? Or is there another way I can arch the doorway?
Mark
fxpiper is offline   Reply With Quote
Old 11-06-2009, 11:59 PM   #2
Extreme DIY Homeowner
Scuba_Dave's Avatar
You want to cut 7" out of a 2x12 (11.25" actual) on a load bearing wall?
Seriously? No.
Add wood on either side to make the curved opening
Or cut the ceiling open & redo all of the support to raise the 2x12 support beams up
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Old 11-07-2009, 10:41 AM   #3
Framing Contractor
Mark
Mark,
I know that this is a DIY forum but even a DIY'er has to have common sense. 2x12 is there for a reason. Obviously cutting 7" out of it like you are describing will never work.
You do have options that no one here can help without seeing it. If you cut 7" out of a 2x12, that will leave you with roughly 4-1/4" left over to the bottom of the double top plate.
You can cut the top plates out and that will give you 3" more making the height 7-1/4" with a 9' span. Depending on the load you are carrying above, you can have a 1/2 x 7-1/4" flitch plate sandwiched in between 2-2x8's and that might work for your 9' span. You would have to have an Architect or Engineer figure this out for you.
Another option is to take the header out and cut the joist back on each side of the wall and install the same 2x12 header flush at the top of the joists above with joist hangers.
An Architect or Engineer might tell you that a 1/2 x 7-1/4" flitch plate won't work and you can get away with a 1/2" x 8-1/4" flitch plate will work. You just need 6" instead of the 7" to gain.
You do have options. Cutting the 7" out of the 2x12 isn't one of them.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-07-2009, 11:45 AM   #4
Knucklez's Avatar
wow....
"if you can't be handsome, at least you can be handy"
Knucklez is offline   Reply With Quote
Old 11-07-2009, 12:02 PM   #5
Civil Engineer
An alternative is to replace the wooden header with a curved steel header, custom designed and manufactured. She is your wife, so money should be no object, which is good, because the design plus fabrication plus installation will certainly set you back several thousand dollars.
Old 11-07-2009, 12:05 PM   #6
Just think how many people are doing what the wife wants without asking someone if it makes sense. ! Fxpiper did the right thing.
bob22 is offline   Reply With Quote
Old 11-07-2009, 12:54 PM   #7
Thanks for the replies. Now I have proof that supports what I thought in the beginning...Dont do it. And I'll leave my comment at that so I don't dig a hole for myself when my wife reads this.
Mark
Old 11-07-2009, 04:06 PM   #8
I'm glad you asked. Everyone is glad you asked. The double 2x12's span 9' can safely carry a load of about 4400#, to cut as mentioned would reduce it to less than 800# if rated species and small knots. It probably would have failed, being 5 times over-loaded.
"so I don't dig a hole for myself when my wife reads this." --- I'm glad that the hole not being dug!
Be safe, Gary
If you have a clothes dryer in an interior room, please check the exhaust ducting for lint build-up!
GBR in WA is offline   Reply With Quote
Old 11-07-2009, 04:19 PM   #9
Scuba_Dave's Avatar
I'd much rather see 10 posts/threads like this asking CAN I
VS 1 thread saying...Hey I just cut this out...does that matter?
Old 11-07-2009, 05:00 PM   #10
If wishes were horses, beggars would ride.
Ron
Old 11-07-2009, 10:49 PM   #11
Cabinet maker
Augie Dog's Avatar
Well, if the boss reads this I want her to know that raising the header into an attic and creating an arch in it's place is about a days work for a good carpenter. Less the drywall finishing and painting, ect. But the structural work is generally not a big deal at all.
If there is a floor above then the size of the joist will determine how much header is left below the ceiling line. But you werre headed for around 4 inches at the top of the arch anyway so the prospects are good that it might work.
The hidden dream squasher would be a toilet drain running through a joist bay or some other mechanical obstruction to stuffing that header straight up into the floor system.
So you could hire a qualified guy at a reasonable fee if it's over the love of your life's head.
if there is nothing in the way that is
Augie Dog is offline   Reply With Quote
Old 11-07-2009, 11:15 PM   #12
I think that your wife needs to deterimine how important the arch is to her. If she just likes the look of and arch then just frame the corners down a little to create an arch, but leave the header alone. I know people that just started cutting and ended up with the house laying on the ground. If she is determined to have the header raised then she needs to be prepared to pay a professional to do it. If not you might be looking at your house with a whole different view.
RobQuillin is offline   Reply With Quote
Old 11-10-2009, 10:22 PM   #13
May be get a new wife that does not want you to do such a dangerous thing.
Arvind is offline   Reply With Quote
More On This Topic
Hi! My name is Jon on behalf of Expert Village. In this video clip, we will be cutting out our kick plate piece. First I am going to measure out 20 1/2 inches on my piece of lumber. Next I am going to bring it over to my radial arm saw and make my cut... Read More »
Hi! This is Weldon Moon on behalf of Expertvillage.com. And the next step in building the spiral is to attach the pole to a fork plate. We have attached in the center of this plate. Then drilled in with a hammer drill, anchored these anchors into the... Read More »
Hi, this is Jon and in this clip we will be installing our fixture box. Now, with the can light that we pulled out, the diameter is about six inches. However, the diameter for our mounting plate is only about four inches. Now, because our opening is so... Read More »
Sometimes you will find yourself in a situation where you need to join two pieces of wood on the angle and quite often it will happen where you are trying to customize doorways and stuff like this. This is where the angle base is helpful to have. Let's... Read More »
How to Make Bookshelf Trim
How to Make Bookshelf Trim by Expert Village
Hi, this is Jon on behalf of Expert Village. In this video clip, we'll be making the trim. Now, on our unit here our top piece is going to have trim on both sides and in the front, so I need three pieces of trim for that. Our bottom piece is actually... Read More »
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 07:31 PM
Load bearing wall removal options ikessky Remodeling 2 08-24-2009 05:18 PM
Load bearing floating wall?? ordoro Remodeling 6 04-20-2009 09:09 AM
Load Bearing Exterior wall however it has an overhanging porch rhoton1 Building & Construction 2 03-16-2009 08:19 PM
load bearing wall no more grant Building & Construction 5 10-14-2007 10:50 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
