Cutting Hole For Window - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-06-2010, 11:33 AM   #1
cutting hole for window
Do I have to get a permit in Massachusetts to have a window hole cut out?
maudite is offline   Reply With Quote
Old 08-06-2010, 11:48 AM   #2
probably. but frankly i wouldn't bother, unless you're in plain view of the street.
if you know how to do it, just do it and close it up quickly.
wombosi is offline   Reply With Quote
Old 08-06-2010, 02:59 PM   #3
Civil Engineer
Rewards Points: 4,692
The only person who can answer your question is the local building inspector. In my experience, they won't hold it against you if you ask. If you go ahead and do the work without a permit, and it turns out you need one, best be on very good terms with your neighbors. If they turn you in, the building inspector is likely to be in a bad mood, which can quickly ruin your day.
Old 08-06-2010, 05:10 PM   #4
Registered User
Rewards Points: 5,482
"Do I have to get a permit in Massachusetts to have a window hole cut out?" ------ No. But to put a new window in, maybe. Your H.O. Insurance may want proof if it is required, to cover any future damage from the install later....
Be safe, Gary
Cutting Vent Hole in Roof How To Wanted wildbilly Plumbing 17 06-02-2010 04:35 AM
Cutting a hole in concrete wall upinsmoke Building & Construction 4 03-07-2010 09:20 AM
Cutting out a hole on a stainless steel sink...pics Goldglv General DIY Discussions 14 02-28-2010 10:04 PM
Cutting hole in basement wall bladesj Remodeling 4 06-14-2009 05:41 PM
Cutting a hole in stone foundation casualty x Building & Construction 2 01-11-2008 06:28 AM
