Cutting HardiPank - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-17-2012, 08:55 AM   #1
jburd964's Avatar
Rewards Points: 166
Cutting HardiPank
I need to cut a lot of small 1.5"x3" slots out of Hardi Plank that is already mounted to wall, to hang shutters. What would be the best way? I'm thinking of using a multi tool with carbon grout plunge blade are something on that line. Any idea's on how to cut it are experience with my method?
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 03-17-2012, 03:28 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I'd say you've got it figured out already (That was the first type of tool and blade that came to my mind).
- Build Well -
Old 03-17-2012, 03:45 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
to hang shutters? why do you need to install blocks?
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
kwikfishron (03-17-2012)
Old 03-17-2012, 04:05 PM   #4
Rewards Points: 13,270
Shutters are hung with screws why the slots? A simple hole with a masonery bit, silicone in the hole is all you need.
Old 03-17-2012, 04:23 PM   #5
kwikfishron's Avatar
Rewards Points: 176
Could be heavy shutters Tom.
There not all made out of plastic.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Tom Struble (03-18-2012)
Old 03-18-2012, 11:15 AM   #6
thus the why?
cutting thru the envelope to install wood blocks may require more info than just what saw to use,depending on it's exposure it may need to be flashed in
Old 03-18-2012, 01:36 PM   #7
Reseal the cut edges, adding drip caps. I can see this being a great place for wall leaks.
Old 03-18-2012, 01:38 PM   #8
and possibly unnecessary?
Tags
backerboard , construction , hardiplank , masonary , remodel
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Cutting Duct ADKstorm HVAC 10 01-23-2011 02:30 AM
Tapering and cutting door casing destroyer427 Carpentry 3 09-17-2009 03:18 PM
Cutting in to baseboards? windowguy Painting 9 02-08-2009 10:20 AM
Cutting Board DaveSteel Carpentry 1 02-21-2008 10:38 AM
