-   -   Cutting HardiPank (http://www.diychatroom.com/f14/cutting-hardipank-137314/)
jburd964 03-17-2012 07:55 AM
Cutting HardiPank
I need to cut a lot of small 1.5"x3" slots out of Hardi Plank that is already mounted to wall, to hang shutters. What would be the best way? I'm thinking of using a multi tool with carbon grout plunge blade are something on that line. Any idea's on how to cut it are experience with my method?
AtlanticWBConst. 03-17-2012 02:28 PM
I'd say you've got it figured out already (That was the first type of tool and blade that came to my mind).
Tom Struble 03-17-2012 02:45 PM
to hang shutters? why do you need to install blocks?
joecaption 03-17-2012 03:05 PM
Shutters are hung with screws why the slots? A simple hole with a masonery bit, silicone in the hole is all you need.
kwikfishron 03-17-2012 03:23 PM
199 Attachment(s)
Could be heavy shutters Tom. :)
There not all made out of plastic.:wink:
Tom Struble 03-18-2012 10:15 AM
thus the why?:)
cutting thru the envelope to install wood blocks may require more info than just what saw to use,depending on it's exposure it may need to be flashed in
joecaption 03-18-2012 12:36 PM
Reseal the cut edges, adding drip caps. I can see this being a great place for wall leaks.
Tom Struble 03-18-2012 12:38 PM
:yes:and possibly unnecessary?
