Cutting Hardiboard Siding - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-11-2006, 09:11 AM   #1
Cutting hardiboard siding
I am residing my house with 8 1/4" hardiboard siding.
Anybody have an opinion on the best way to cut hardiboard siding? How about handling it when you have to notch around windows, doors, etc, it seems pretty brittle. Do you just blind nail it or face nail it as well? How tight should you try to get it to fit, or don't worry and let caulking take care of it?
Thanks,
mcwilson
mcwilson is offline   Reply With Quote
Old 11-11-2006, 01:45 PM   #2
Darylh's Avatar
I use a carbide tooth blade to cut it. I leave 1/16- 1/8" space on the but end joints and caulk. I blind nail most of the time so it moves with the climate changes.
Darylh is offline   Reply With Quote
Old 11-11-2006, 07:08 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Thanks,
mcwilson
Brittle: It isn't as brittle as you might think it would be.
Also, don't breath the dust created by cutting it.
As mentioned already, blind nailing is fine, no need to face nail it. You can caulk the edges like normal cedar clapboards.
- Build Well -
Old 11-17-2006, 12:53 AM   #4
Answer
All of your questions can be found on the website of James Hardi siding. They have a section on installation instructions. Hope that helps
dyoung162@sbcglobal.net is offline   Reply With Quote
Old 11-18-2006, 11:33 PM   #5
make sure to use the right fastners
ncor is offline   Reply With Quote
Cutting Aluminum siding gmjosey Carpentry 3 12-16-2006 11:55 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
