Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-03-2009, 11:16 AM   #1
Cutting granite tiles
Am trying to tile an island that my wife wants to extend out about a foot or so to make it into a breakfast eating area. The problem is she would like it curved and with my tile saw I can't do this. What do I need to cut in a curve.
sgtrock is offline   Reply With Quote
Old 02-03-2009, 11:27 AM   #2
Remodeling Contractor
With a 4" grinder you can cut a curve with a diamond wheel. Just do not cut all the way at first, turning around the curve and then again deeper. Now use a diamond grinder wheel to fine tune the shape. Next you need to use wet diamond disks from 50-8500 grit to polish the edges. Equipment if you do not have it (you don't) will cost about $1000. SOOO,,,, bring to a granite shop and have them do it for you, may not cost much at all. Make a template of the cuts you need with the edge profile and location specified.
Old 02-03-2009, 06:08 PM   #3
agree w/bobby - 4" grinder w/.110 blade's the way to go,,, i do it a bit differently in that i make a series of chord cuts then use the blade edge to finish the curve.
not sure how much luck you'd have polishing tile so i defer to bob,,, edge polishing granite's not all that difficult w/dry pads but reg 4" grinder's too fast,,, usual difference 'tween pro's & diy-er's is ability AND tooling
yesitsconcrete is offline   Reply With Quote
Old 02-04-2009, 08:00 AM   #4
for the help. Also what do you think of using a grout colorant? Easy to do,
hard to do or not worth it?
Old 02-06-2009, 12:12 AM   #5
I saw a segment on HGTV Pro where they filmed a guy cutting a granite tile on a wet tile saw. He was using a contoured diamond blade called
Arcus. I went to you tube and saw the same blade cutting curves in marble, travertine and porcelain on a wet tile saw. There is a product site www.arcusblade.com with more info and a phone #.
losttool is offline   Reply With Quote
Old 02-06-2009, 07:03 AM   #6
Grout colorant is used to change the color of a grout already installed. You should be able to find grout the color you want to use. But using the colorant is easy to do. With granite tiles, lay them without a spacer for best look or at least no more than 1/16" spacers.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 12:44 PM
Cutting Unusual Backsplash Tiles Tool Junkie Tiling, ceramics, marble 7 12-16-2008 08:28 AM
Hardwood surronded by granite tiles coleen66 Flooring 11 03-22-2008 09:08 PM
Installing 24" granite tiles over existing kitchen countertop? pford Carpentry 3 01-25-2008 11:16 PM
