Cutting Exiting Baseboard Flush With Tile - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-06-2007, 02:28 PM   #1
Cutting exiting baseboard flush with tile
Is there a trick or a good tool that you might suggest to cut the molding level sith the tile. I do not want to fight the grout. Thanks...
mowedthelawn is offline   Reply With Quote
Old 06-06-2007, 05:12 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Maybe it's me? Can you re-phrase your question, I don't quite understand it.
(Do you mean doing an "under-cut" on the bottom of the baseboard for the tile to slide under?
If that is what you mean, I would suggest that you simply pull all the baseboard off in the area, and re-install after...or use new baseboard.)
- Build Well -
Old 06-06-2007, 08:19 PM   #3
I want to install a new baseboard. The tile was installed up against the original baseboard and grouted in, which means that I would have to dig up the grout and fight to get the old baseboard out. I just want to get a clean cut at floor level to remove the portion of the baseboard that is above the tile and then install a new baseboard using the tile and the remaining baseboard as my base. I have heard of a "Jam" saw.. would this work for me?
Old 06-06-2007, 08:54 PM   #4
.....I have heard of a "Jam" saw.. would this work for me?
Under Cut Jamb saw might work. You can rent them:
http://www.tools4flooring.com/crain-...saw-p-282.html
Also, don't underestimate a nice sharp chisel to clean things up.
- Build Well -
Old 06-06-2007, 10:57 PM   #5
Thank you AtlanticWBConst.......I think that I will need to use both the jam saw and the chisel as it will be very tight in the bathrooms.
Old 06-06-2007, 11:02 PM   #6
Although you probably wouldnt want to buy it ($300+)...the Fein Multi- Master would make a very clean (but slow) cut.
send_it_all is offline   Reply With Quote
Old 06-06-2007, 11:29 PM   #7
Custom Cabinet Maker
Mowed: you can also try this: leave old in place, nail new to cover it and make a "filler" at the top, this way all looks great and way less work. Most base is only 5/8 thick. at the casing you will have to get "artistic" Maybe a faux Plinth block
JackM
skymaster is offline   Reply With Quote
Old 06-07-2007, 05:57 AM   #8
I was think about that tool as well, but couldn't remember the name of it.
For anyone curious about that tool, here's a link on Amazon for it:
http://www.amazon.com/Fein-MSX-636-2...1213753&sr=8-3
- Build Well -
Old 06-07-2007, 10:25 AM   #9
why would someone installl tiles without removing the baseboard first?
KUIPORNG is offline   Reply With Quote
Old 06-07-2007, 07:49 PM   #10
That's an excellent question, but it happens all the time. Some possible answers are:
Lazy
Cheap
Frugal
Not in love with physical labor of any sort
Financially "snug"
Cheap
did I mention cheap?
Last edited by AtlanticWBConst.; 06-08-2007 at 03:23 AM. Reason: minor language reference
Old 06-07-2007, 08:19 PM   #11
Alot of what you say may be true...........but not knowing any better may be added to your very astute observations. I thought the purpose of this board is to inform and learn. Well consider me in school.
Old 06-07-2007, 09:40 PM   #12
remodeling pro
Reciprocating saw ,"Sawsall" ,with a 9 inch blade. A metal cutting type with the fewest number of teeth works good because they are pretty flexible, but they are slower than a wood cutting type, and also break easier. Unless it is true 3/4" material, I don't even usually cut in this situation. The typical thin base boards will split very easy with a sharp chisel and a little upwards pressure from a flat pry bar. The areas that break higher than the tile can easily be cut down with the chisel.
troubleseeker is offline   Reply With Quote
Old 06-08-2007, 12:27 AM   #13
...and now I'm in school. I have inadvertantly insulted you while trying to be a little bit funny...(very little bit, i now realize). Sorry about that. When I was typing my post, I was actually thinking about customers I have had who have asked me to tile their floors in that same manner, because they didnt want to pay for new base. What I wasnt thinking about was the possibility that this thread might have been started by the person who tiled your room without changing base.....now I feel bad.
Old 06-08-2007, 11:40 AM   #14
This is a awesome tool.. I have it, and it works wonders.. I would have to say that this is my most favorite tool.. I just did my kitchen, cut baseboards very easy, while still on the wall.. I was able to cut everyting, except for tile.. BUT it has a grout cutter, just wont cut the tile it's self..
ImFlippinCrazy is offline   Reply With Quote
Old 06-10-2007, 04:49 AM   #15
Old School
cabinetman's Avatar
The few times I had to do this, undercut saws didn't cut close enough to the tile. Since the base is more than likely not nailed from the tile line or below, this is what worked for me. Pry base loose and remove completely. The grout doesn't really stick to the base, so it comes out with a little coaxing. Once out, re-grout space and install new base. By the time you have cut off the base and trimmed it flat to the tile, which would be a chore, and assuming you didn't damage any tile, there may be remnants of old cut base that may show in front of the new. Any areas like that won't take more grout.
cabinetman is offline   Reply With Quote
Tile vs Wood as a baseboard MattCoops Flooring 14 11-12-2014 03:26 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Tile Baseboard leted_82 Flooring 3 07-07-2007 11:57 AM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
