Cutting Dowel Rods - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-28-2012, 05:33 PM   #1
Cutting Dowel rods
i need to cut dowell rods on a 60 degree angle. one isnt a problem but 4000 is . any ideas on how to mass produce a 9" long dowell with 60 degree angle on both ends? need to cut as many as i can at a time to make it profitable to do so. tried lots of jigs on table saw and mitre saw. cant seem to get them clamped down good enough to keep them from rolling or shootin across the room.
shmidlap is offline   Reply With Quote
Old 09-29-2012, 01:17 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
  • What size dowel
  • Does it have to be wood?
  • Do the 60 deg ends have to be in the same plane?
  • What is the length tolerance overall?
  • What is the length tolerance between individual dowels
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-29-2012, 08:12 AM   #3
How about building a "box" with 3 sides (no top and open ends) to the appropriate length/angles to hold the dowels in and use your box as your guide? Maybe hold a piece of wood on top of the dowels to hold them in as you cut? I have no idea if this would work, but this is probably what I'd try if faced with 4000. Probably not going to be as precise as cutting individually though.
Pianolady is offline   Reply With Quote
Old 09-29-2012, 10:09 AM   #4
dowells
to palibob: dowells are 5/16 hardwood, plane dosent have to be same,need to cut them 8 3/4" with 1/8" tollerance. i do have a bandsaw but was concerned about the ends fuzzing. ive made several sleds for table saw and mitre box as well. in theory they work but just cant get enough pressure to keep them from moving.
Old 09-29-2012, 10:18 AM   #5
dowells
great idea! but ive tried that, cant get enough downward pressure to keep them from spinning.ive come up with several variations of that on sleds for table saw as well as mitre saw. seems combination of round dowell, round blade and angle dont work to well. makes a good dowell launcher though. i have a few dowell size holes in the wall to prove it. may have to resort to band saw.
Old 09-29-2012, 10:19 AM   #6
AHH, SPANS!!!
Rewards Points: 1,166
you will need an 8 3/4" material stop for the miter saw. maybe even figure out a way to make the stop on an angle so that once the piece is seated into the stop your cut angle will be oriented in the same direction. this will maybe be the fastest way even though it is one at a time...
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
mae-ling (09-29-2012)
Bosch 11245EVS Rotary Hammer Drill for Ground Rods tedallen Tools 0 06-02-2012 04:52 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Help - hanging curtain rods in drywall ontheDB Drywall & Plaster 8 10-10-2009 09:54 AM
