Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-26-2009, 08:07 PM   #1
cutting crown molding for cope cuts
I'm planning on using 45/45 spring angle crown, 4.5 inch wide and will be using a 12 inch compound miter saw.
What angles should the saw be set at to cut the face profile of the molding so I can make the cope cut with the coping saw. A chart I'm reading says I should be using a miter angle of 35.3 and a blade tilt of 30.0 for 45/45 spring angle crown for a 90 degree corner. Am I interpreting this chart correctly?
billyg is offline   Reply With Quote
Old 04-26-2009, 08:14 PM   #2
Drywall contractor
If you're cutting a compound miter, you don't have to cope and the crown is cut laying flat. If you're coping, you cut on a 45 with the molding "bedded" on the saw upside down...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-26-2009, 09:53 PM   #3
To check the angle combination, just take some scrap 1x4 and cut them. If they come together at 90 degrees, that's the setting.
Ron
Old 04-27-2009, 02:10 PM   #4
Old School
Willie T's Avatar
Forget trying to manage the tilted 'compound' bevel on a miter saw. Besides the fact that you don't need to bother with it at all, very few walls are square enough in all the planes involved at a corner to make any of those numbers work much of the time. You will end up with much beter work if you cope your inside corners and cut your molding "UPSIDE DOWN, AND BACKWARD" with nothing but a 45 (more or less, depending on how bad the corner was built) angle on the saw for all cuts.
Just remember that phrase,"UPSIDE DOWN, AND BACKWARD" and you will soon begin to see how it works.........
You always put your molding on the saw table....... "UPSIDE DOWN".
And you simply remember to turn your saw the direction shown in the pictures I show below for each of the desired cuts, and place your molding on the saw table "BACKWARD". In other words, if you want to cut a piece for the right side, you place the wood on the left of the saw blade. If you want to cut a piece for the left side, you place the wood on the right side of the saw blade.
Why all this "UPSIDE DOWN, AND BACKWARD" craziness? Well, think about it.
You are installing molding against the intersection of your wall and your ceiling. Those two planes (or surfaces) create a 90 degree angle when they meet. That's pretty simple. You can look right up there and see that.
Well, the table and the backing fence of your miter saw also create a 90 degree angle where they meet. Think of the fence (the upright part) as your wall surface... and the table of the saw as your ceiling. That's cool. You can look at the saw and see that, too. That's all well and good. You need a 90 degree setup like that to help align the molding. But here comes the aggravating part.
Because of the fact that a miter saw happens to have its blade mounted ABOVE the table you're cutting upon, it cuts the molding the opposite of what you need for it to install properly up there on your ceiling.
Envision this: If it were possible for you to lie on your back like Michelangelo did to paint the ceiling of the Sistine Chapel... and if you could bolt your saw, upside down, directly onto the ceiling... then you could make all your cuts just like they look like they need to be cut. Because the saw would then be oriented along the same plane as the ceiling. But that's a huge hassle. And totally ridiculous to even attempt.
So... you just need to keep remembering that you are, in effect, doing everything in reverse. Because of the saw being on the floor, and not the ceiling, the molding is actually being prepared in reverse, (until you turn the cut piece of molding over and lift it up into place on the ceiling), so all your cuts are going to also have to be done in reverse.
I know it doesn't seem to make any sense right now, but as you read through this a few more times ... slowly... it will begin to come into focus.
Inside Left ........................................... Inside Right .................................Outside Left .............................Outside Right
Willie T
Old 04-27-2009, 02:18 PM   #5
Drywall contractor
I tried the compound miter method once. Never again. Good explanation Willie. I forgot the "backward" part...
Old 04-27-2009, 04:59 PM   #6
And...... check out the niffty install tool:
http://www.google.com/url?sa=t&sourc...VLV6WguQE-RLug
Be safe, GBAR
GBR in WA is offline   Reply With Quote
Old 05-04-2009, 07:18 PM   #7
Joe-J
Wow!!! You guys are good!!
Joe-J is offline   Reply With Quote
More On This Topic
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an inside corner. Crown molding sits against the wall usually at a 38 degree or a 45 degree that depend on the type of... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on a wall that takes a 45 degree turn. What we want to do is take the two pieces of crown and we will need to cut them both... Read More »
Hi! I’m Rob McMahon for Expert Village. Now, although ripping is primarily what you’ll do with your table saw, you can also perform cross cuts with a miter gage. This saw has one that's stowed on board. Remove our fence and set that right on... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip we are going to demonstrate how to cut an inline joint with a miter saw in crown molding. You might think that cutting your corners at the compound miter setting that you would... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an outside corner with a miter saw. It is pretty similar to cutting on the inside corner, so if you just change your miter... Read More »
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
Door framing and crown molding finnishing question amdspitfire Painting 7 06-09-2008 02:49 PM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 08:11 AM
crown molding cuts, geometrically impossible ?? pcjeep Carpentry 7 02-28-2008 09:25 PM
crown molding cutting angles iti Carpentry 3 12-22-2005 09:26 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
