Cutting Countertops - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-13-2005, 12:52 AM   #1
Cutting countertops
This may sound remedial but what would be is the best way to get a clean 45 deg cut on a counter top? I would hate to to get some dust in my eye
armycarpenter is offline   Reply With Quote
Old 10-13-2005, 01:15 AM   #2
renovations
What material is the counter top? Laminate? Where is the 45? (against a wall, at the leading edge, on a mitre joint?) Tell us about your project, it will help narrow down some options.
Bonus is offline   Reply With Quote
Old 10-13-2005, 01:29 AM   #3
this is what im dealing with
A brand new set of kitchen cabniets. no problem to install to include the counter BUT there is a 45deg miter at the 90 deg wall. just like typical kitchens. I dont want a bad cut in a counter top. what would you do to mke certian it was a perfect straight cut?
Old 10-13-2005, 01:33 AM   #4
renovations
I get the counter guys to do it for me, they have mitre saws that cut it straight and tools for routing the clamp cavities underneath that hold it all together.
Old 10-15-2005, 10:39 PM   #5
Contractor
KenTheHandyMan's Avatar
Rewards Points: 150
I am going to tell you that this is a very difficult cut to make. If you have a laminate blade, it can be done on a table saw with the proper jig, but other than that, I would not advise it. I have had to do some in a pinch and used a level and clamp system with an old fashioned circular saw. The blade is critical though, or you get chips.
Be sure you have access to the proper color Seam-Fill if you want a pretty job. Did you build the countertop or does it have a prefabbed backsplash?
Regards,
Ken Walker
KenTheHandyMan is offline   Reply With Quote
Old 10-29-2005, 08:53 AM   #6
Clamp a straight edge to your material for your circle saw to follow. You will need a blade compatible with the material you are going to cut. You need a little scrap to practice on. Some materials seem to cut better is you take a light scoring cut first.
kesac is offline   Reply With Quote
Cutting Duct ADKstorm HVAC 10 01-23-2011 02:30 AM
cutting glass victor General DIY Discussions 2 08-07-2007 12:51 AM
Install granite countertops first or stone backsplash?? ncoppola09 Remodeling 32 02-20-2007 02:00 PM
Kitchen sink/counter cutting help? Lambo Carpentry 4 06-17-2006 05:50 AM
advice on new countertops skits Remodeling 1 04-20-2006 12:03 AM
