Cutting counters
The two drawer banks should be a seperate piece (or pieces) from the rest. Find the screws that hold them together and remove whatever needs to be removed to get the drawers out.
EDIT: OK, maybe that's wishful thinking. I guess I should say, IF YOU'RE LUCKY, the two drawer banks are seperate from the others. If they're not, just try to cut on the drawer side of the board between the two cabinets (or in your case between the cabinet and the drawer bank). Try to cut it flush with that board.
