Cutting Corian - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 05:32 PM   #1
Cutting Corian
We have a Corian counter with a drop in cooktop and slide in oven. We are replacing these with a freestanding range. We need to create a 30" open space for the new range. What do we need to do to cut the countertop? We need to do this by 4/12/10!
SarahFell is offline   Reply With Quote
Old 04-09-2010, 07:58 PM   #2
Remodeling Contractor
a saw with a carbide blade or a router with a carbide bit. Only requirement for cutting corian is the carbide cutting edge.
The Following User Says Thank You to Bob Mariani For This Useful Post:
SarahFell (04-09-2010)
Old 04-09-2010, 09:11 PM   #3
Rewards Points: 5,336
In order to make the cut all the way to the wall, you'll need to move the counter away from the wall. Left in place. a standard 7 1/4" saw will only get you within 4 or 5" from the end. A trimmer router maybe 2".
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
SarahFell (04-10-2010)
Old 04-10-2010, 03:15 PM   #4
http://search.harborfreight.com/cpis...ster&Submit=Go
Using one of these you can probably cut all the way to the wall. They are very handy to have around for general home improvement. They will do a lot that regular saws will not do. Available from other manufactures if you desire a better quality tool. Bosch and Dremel have one as well as Fein for the top of the heap quality.
Mike in Arkansas is offline   Reply With Quote
The Following User Says Thank You to Mike in Arkansas For This Useful Post:
Corian sinks--need advice! Asap! Please! donnatella General DIY Discussions 10 05-15-2011 10:37 AM
Cutting Duct ADKstorm HVAC 10 01-23-2011 01:30 AM
How can you cut a piece of Corian coutner? Sephora Kitchen & Bath Remodeling 3 05-06-2009 06:54 AM
Cutting in to baseboards? windowguy Painting 9 02-08-2009 09:20 AM
Cutting Board DaveSteel Carpentry 1 02-21-2008 09:38 AM
