Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-06-2012, 08:57 PM   #1
Cutting a butcher block top
I have a small roll away thing in my kitchen that has a butcher block on top. It is about 1 1/2" thick. My space between the dishwasher and stove is very narrow and that is where I've got the piece. Can the butcher block be cut successfully? It has rounded corners. Is there any way to round the corners some after cutting it? Thanks!
franincanton is offline   Reply With Quote
Old 01-06-2012, 09:50 PM   #2
Civil Engineer
Butcher block is typically hard maple. It can be cut successfully using a variety of tools, including a circular saw, table saw, chop saw, or a router. After it is cut to size, you can get rounded edges using a router with an appropriate carbide tipped bit.
Old 01-06-2012, 11:02 PM   #3
Thanks for your expertise. Have a nice weekend.
Old 01-07-2012, 05:30 PM   #4
If using a circular saw cut from the backside and use a straightedge. Gives a cleaner cut.
mae-ling is offline   Reply With Quote
Old 01-07-2012, 05:33 PM   #5
The butcher is typical with the different color woods next to each other. There are definite lines where the woods butt up to one another. Is there a good way to saw a nice clean line between the two woods? Hope I'm clear with my explanation. I don't want where the wood is glued to each piece to come apart and then I have a mess.
Old 01-07-2012, 05:41 PM   #6
Not going to happen there glued together.
No router, just sand the edges to make it rounded.
Apply some mineral oil to the exposed edges.
Do not use vegatable oil it will go rancid.
oh'mike (01-07-2012)
Old 01-07-2012, 06:25 PM   #7
Super Moderator
Modern wood glue is stronger than the wood it holds together---
I second Joes suggestion--sand paper will round over the edge just fine for a small project like that--
Old 01-09-2012, 02:15 AM   #8
yeah, sanding carefully you can re-create the rounded edge pretty well.
Remember the saw blade will take an eighth of an inch when cutting. As mentioned cut with good side down when using a skillsaw, make sure to use a good finishing blade, I find a skillsaw works best, straitedge is a good idea as well. Often easier to apply your oil/finish before installing it.
chrisBC is offline   Reply With Quote
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 08:03 AM
After cutting concrete block... TipsyMcStagger Building & Construction 8 12-01-2011 08:28 PM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 10:32 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
Cutting cinder block for a large door opening joeyb Building & Construction 2 02-10-2008 01:00 PM
