-   -   Cutting a butcher block top (http://www.diychatroom.com/f14/cutting-butcher-block-top-129067/)
franincanton 01-06-2012 08:57 PM
I have a small roll away thing in my kitchen that has a butcher block on top. It is about 1 1/2" thick. My space between the dishwasher and stove is very narrow and that is where I've got the piece. Can the butcher block be cut successfully? It has rounded corners. Is there any way to round the corners some after cutting it? Thanks!
Daniel Holzman 01-06-2012 09:50 PM
Butcher block is typically hard maple. It can be cut successfully using a variety of tools, including a circular saw, table saw, chop saw, or a router. After it is cut to size, you can get rounded edges using a router with an appropriate carbide tipped bit.
franincanton 01-06-2012 11:02 PM
Thanks for your expertise. Have a nice weekend.
mae-ling 01-07-2012 05:30 PM
If using a circular saw cut from the backside and use a straightedge. Gives a cleaner cut.
franincanton 01-07-2012 05:33 PM
The butcher is typical with the different color woods next to each other. There are definite lines where the woods butt up to one another. Is there a good way to saw a nice clean line between the two woods? Hope I'm clear with my explanation. I don't want where the wood is glued to each piece to come apart and then I have a mess.
joecaption 01-07-2012 05:41 PM
Not going to happen there glued together.
No router, just sand the edges to make it rounded.
Apply some mineral oil to the exposed edges.
Do not use vegatable oil it will go rancid.
oh'mike 01-07-2012 06:25 PM
Modern wood glue is stronger than the wood it holds together---
I second Joes suggestion--sand paper will round over the edge just fine for a small project like that--
chrisBC 01-09-2012 02:15 AM
yeah, sanding carefully you can re-create the rounded edge pretty well.
Remember the saw blade will take an eighth of an inch when cutting. As mentioned cut with good side down when using a skillsaw, make sure to use a good finishing blade, I find a skillsaw works best, straitedge is a good idea as well. Often easier to apply your oil/finish before installing it.
