Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-22-2009, 10:50 AM   #1
Cutting bullnose crown molding...
Yesterday I took on the task of installing crown molding into my brothers home. Most of the corners are 90 degrees with the exception of 4; 3 bullnose and one 125 degree wall.
I started with cutting and installing most the 90 degree pieces yesterday. Today I will be finishing the rest of the house..
Here's my issue; Yesterday I tried making a few test cuts for the 22.5 degree outside bullnose but for some reason I can't figure it out. I've searched google and youtube and have found a couple videos/explanations however each video includes the use of a jig that the company is selling - I'm only using my trusty Hitachi C10FSH.
Does anyone have a link to instructions or video explaining how to cut an outside bullnose with a sliding compound miter like the C10FSH.
Thanks !
EDIT: For the sake of argument - Lets say his bullnose corners are exactly 90 degrees so we'll use 22.5 degrees
jaysen is offline   Reply With Quote
Old 09-22-2009, 01:12 PM   #2
Tool Geek
PaliBob's Avatar
Originally Posted by jaysen View Post
.... Does anyone have a link to instructions or video explaining how to cut an outside bullnose....
Jaysen see if this helps:
http://www.veoh.com/browse/videos/ca...181697jkynpb24
or
http://www.youtube.com/watch?v=s2Dkjnt_GME
another
http://www.youtube.com/watch?v=3S_gq_auZSw
And Finally from the Crown Molding King Gary Katz:
Scroll down to "Conquering Crown Molding"
http://multiblades.com/GaryKatzdvd.html
The secret is after cutting the pieces is to pre-assemble the corners with a super fast adhesive. Pro's use 2P-10:
http://www.amazon.com/s/?ie=UTF8&key...l_7iqtfdr5s2_e
If you wait 5 minutes or so you can use a slower setting adhesive. I Like:
Loctite "Power Grab" also available at LOWE'S or in 300mL gunable tubes
http://www.amazon.com/Henkel-01-0675...sr=8-2-catcorr
Another fast setting Wood Molding glue that I like is:
http://www.amazon.com/Franklin-Inter.../dp/B0002YXDWQ
This is much faster setting than Titebond I, II, or III
Hope this helps
Disclaimer
& Stay Safe
.....Bob
More On This Topic
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on a wall that takes a 45 degree turn. What we want to do is take the two pieces of crown and we will need to cut them both... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an outside corner with a miter saw. It is pretty similar to cutting on the inside corner, so if you just change your miter... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip we are going to demonstrate how to cope crown on an inside corner. The reason that you might cope crown molding, is that sometimes your walls maybe out a little bit, your angle... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip we are going to demonstrate how to cut an inline joint with a miter saw in crown molding. You might think that cutting your corners at the compound miter setting that you would... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an inside corner. Crown molding sits against the wall usually at a 38 degree or a 45 degree that depend on the type of... Read More »
Cutting crown molding helpless handyman Carpentry 12 08-29-2009 02:30 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
Paint Crown Molding Before or After Installation? gmhut Painting 24 06-03-2009 09:38 PM
cutting crown molding for cope cuts billyg Carpentry 6 05-04-2009 07:18 PM
crown molding cutting angles iti Carpentry 3 12-22-2005 09:26 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
