I'm re-doing some kitchen cabinets and I've created a panel insert that will simply glue to the the exiting cabinet door's flat front face to make it look better.
The problem is that the wood for the panel started off as 3/4 in height and I need to saw off 6/16'ths inch from the bottom in the height direction so the panel sits into the door and can be blended in seamlessly. My table saw won't make it to the halfway mark because the wood is 12" wide. I don't own a bandsaw which is what I'm thinking would be the best thing to use but I do own a lot of other tools.
Any suggestions on ways to make this cut?
This is the cabinet door:
The panel insert laying in the door:
Panel close-up with a line indicating the cut:
