Cutting Board - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-20-2008, 12:38 PM   #1
Cutting Board
I'm thinking of making a cutting board. Everything I read says to cut the pieces into uniform thicknesses (like 1") and then glue together.
Question 1: Is it important that the pieces be uniform in thickness, or is that instruction just for the best look?
Question 2: Is there a risk to make a cutting board from a few wide pieces (like 4" or 5")? Or even a small cutting from one piece?
Thanks.
DaveSteel is offline   Reply With Quote
Old 02-21-2008, 10:38 AM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
No issues. You will want to use, primarily, quarter saw wood. It will help with warping. Quarter sawn grain has the rings of the wood going from the surface of the cutting board to the bottom, not from side t side.
If all quarter sawn then width shouldn't matter. Thin is fine and adds visual interest. Many will also mix wood species
See this link for some ideas
http://www.forums.woodnet.net/ubbthr...fpart=all&vc=1
-B.
Brik is offline   Reply With Quote
Board cutting problem ADKstorm Carpentry 15 04-04-2008 08:27 PM
Painting the inside edge of cutting board slots 1655graff Painting 8 01-28-2008 08:51 PM
cutting bead board scatterbrain General DIY Discussions 3 01-09-2008 09:13 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
