Cutting Baseboards On The Wall?? - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-16-2008, 11:07 PM   #1
Unhappy
Cutting Baseboards on the Wall??
I got ambitious a couple of weekends ago and replaced ball the baseboards throughout the first floor of my house with spankin new 5 1/2 inch with a shoe molding that goes to the hardwood flooring. Trouble is that after I have painted, caulked, spackled, etc my lovely new baseboards, I purchased new wall mounted air diverters (registers?) and they are all about half and inch too wide! So, I am looking for a way or any special tool that anyone can suggest that I can cut my new baseboards down without taking them off and re-installing? I would prefer to damage the drywall in the back as little as possible too. Or........do I just say forget it any purchase custom sizes grills? Thank you
chefwillymac is offline   Reply With Quote
Old 09-16-2008, 11:36 PM   #2
Registered User
Termite's Avatar
You're not going to find custom sized air grilles, so cutting the baseboard is the way to go.
For pure ease of doing it, there's nothing better than the Fein MultiMaster tool. But, being super-nifty and German-made, it is pretty expensive. It is one of those tools that you'll never know how you lived without it after you get one, but shelling out the money to get one is a challenge. $300+, but you'd be done in two minutes, and you'd have a heck of a fun tool. I bought one for a specific task a few months ago, and have since used it for a dozen other things.
You can get an inexpensive Japanese "dozuki" pullsaw and do the top few inches of it with that. Woodcraft sells them, and I think that even Stanley or Irwin makes a cheesy one that you can get at Home Depot. I'd go with a $40 number from Woodcraft, and you'll have a great little saw. The bottom of the base and the shoe can be finished up with a very sharp chisel a little at a time.
Old 09-17-2008, 09:59 AM   #3
Mold is not my friend.
Mmmmmm. Multimaster. I want one of those but I have to wait until I have a project that justifies the expense.
Rubu is offline   Reply With Quote
Old 09-17-2008, 10:51 AM   #4
Rewards Points: 1,088
The Multimaster is selling for about $400 now.
Also, the cost from some of the attachments can add up. I figure the cutting attachments are pretty much disposable.
handy man88 is offline   Reply With Quote
Old 09-17-2008, 11:29 AM   #5
Custom Cabinet Maker
Bosch make a powered little backsaw, works great. You will have to pop the base loose for a few inches back, slip a cedar shake behind it then cut, this way you dont cut the wall, renail and touchup. Easiest way I know of, at least that is how is the way I do it .
Bosch model 1640vs, about 100 bucks at Lowes
skymaster is offline   Reply With Quote
Old 09-17-2008, 02:12 PM   #6
Rewards Points: 81
Dremel is coming out with their version of the Multimaster in October, you can pre-order it now for $99.99
daxinarian is offline   Reply With Quote
Old 09-17-2008, 03:31 PM   #7
Registered User
Termite's Avatar
No, I just bought one. Woodcraft sells them for $209 with two blades and the sanding kit, which is enough to get you started. The "top" kit that I got...Comes with all sorts of goodies, a case, and attachments...Costs $399.
Old 09-17-2008, 05:34 PM   #8
BUILDER / REMODELING CONT
buletbob's Avatar
I have heard about this tool from a few contractors. they swear by it. I guess I'll have to check it out.
What i have done when cutting baseboard in place is the dewalt roto zip. i had to cut in hot water baseboard end caps into the base mould. it worked beautiful. but pay strict attention if your going to free hand it. BOB
Old 09-18-2008, 03:27 AM   #9
MDF or wood baseboard? I put base blocks and rosette corner blocks on all my doors recently. I used one of those super thin japanese saws and an aluminum level as a straight edge to cut the wood moulding around the doors and the MDF baseboard. It worked great. Just don't use your thumb to push on the back of the saw...It's so thin that it will cut you like a razorblade before you realize what happened. To get close to the floor, I used a sheetrock knife. I pushed some flashing under the baseboard where it met the hardwood to keep from damaging the floor.
KHouse75 is offline   Reply With Quote
Old 09-18-2008, 08:40 AM   #10
Registered User
Termite's Avatar
That's the saw I was talking about...Very handy little thing!
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Cutting a wall? frankthetoad Painting 17 08-07-2007 12:59 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
